Old 2nd May 2011, 06:43 PM   #1
Send a message via MSN to audio_tony
Default DIY transmission lines - thin upper bass?
I have a pair of DIY built transmission lines ( 2 way ), based on Audax drive units.
I didn't build these myself, however I have changed the crossovers from the originals, which were generic off the shelf 2 way crossovers.
I have an issue that the upper bass seems a little thin.
I note on the frequency response graphs I produced, that there is a large 'suck out' in the 150hz region, which based on comparisons with the same drivers in a ported cabinet, does not exist.
Attached are graphs with the final graph from a Wharfedale 9.1 for reference.
The first graph is in the TL cabinet, the second graph is the same drivers and x-over in a conventional ported reflex cabinet (Proac 2.5 clone), the final graph is a Wharfedale 9.1 front ported standmounter.
I didn't use any real sophisticated measurement techniques.
I used "FuzzMeasure" to make these graphs, with a fairly decent microphone, and a Tapco firewire mic amp / digitizer.
So to my question!
How can I cure the "suck out"? I have experimented a little with damping in the transmission line, and also around the (rear) outlet.
I also realise that my room (I just measured in my lounge!) could have an effect on the lower frequency registers, but I would have thought that would only effect below 100hz or so?
I did move the speakers into an open space to perform the measurements - they were all well away from the wall and other objects.
Cabinet dimensions are:
H) 88cm
W) 21cm
D) 30cm
Rear 'port' (TL outlet)
H) 9cm
W) 13cm
Height from top of cab: 12cm
Woofer center is 64cm from bottom of cab.
Searchable DAC list (now in a database). * Easy searching of DAC chips / transport etc. *
Old 2nd May 2011, 07:14 PM   #2
frugal-phile(tm)
planet10's Avatar
The suck-out is likely caused by insufficient attenuation of the 1st unwanted line harmonic. These days ne usually uses a driver offset to kill this. Otherwise dampng needs to be increased (loosing extension).
Pictures or drawing?
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 2nd May 2011, 08:13 PM   #3
I've not had time to draw the enclosure as yet.
Here are some pics of the outside if it helps?
From what I have been able to ascertain (from feeling around the cabinet!) is described in the attached image.
This is something I have just "knocked up" in 15 minutes.
Removing the drive units doesn't give me any further access, and the cabinets are completely sealed.
I have been led to believe this is an Audax kit from the mid 80's but I'm not 100% certain.
Old 2nd May 2011, 11:34 PM   #4
Do a "Ground Plane Measurement".
AmpsLab.com
Old 3rd May 2011, 06:14 PM   #5
I had to research that one - thanks to Google for the answer :-)
I'll try this at the weekend.
Do you expect the Ground plane measurement to stop the 'suckout'?
The problem for me is, I can hear this as a distinct 'thinness' to bass guitar and other instruments around that frequency.
Old 4th May 2011, 03:23 AM   #6
The "Ground Plane" measurement is not a treatment. It's simply another approach to taking measurements. Others are "Nearfield" and "Pit". All these methods have their own advantages.
The "Ground Plane" measurement is a good start to find out the cause of the "suck out". Give it a try, it's worth the effort.
I know what you mean about that "thiness". I find it very tiring to listen to music with that "suck out".
AmpsLab.com
Transmission lines duderduderini Multi-Way 2 29th July 2007 11:56 AM
Transmission Lines matthulme Multi-Way 12 8th December 2006 12:09 AM
Telescopic PVC exhaust pipe bass transmission lines? VvvvvV Multi-Way 5 5th August 2004 06:57 AM
transmission lines Dave Jones Multi-Way 9 2nd August 2003 05:06 AM
Page generated in 0.08425 seconds (80.89% PHP - 19.11% MySQL) with 11 queries
