Recently someone told me that speaker impedance doubles when it approaches maximum power. Do you guys have any info about that, or maybe even a set of impedance graphs at various ouput power?
That would be the best I could imagne to get me some insight on this
#2 |
Speaker impedance usually varies with frequency.
If xmax is passed then the impedance could change.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
There is no doubt about frequency, but i was wondering if the frequency-impedance plot changes significantly with power.
#4 |
Speakerholic
I wonder if they are referring to Power compression? Here's a little snippet I grabbed from the web:
Quote: What is "power compression"? Speaker voice coils are made of copper or aluminum. As these voice coils increase in temperature during normal operation, the DC resistance of the voice coil increases. Greater voice coil resistance means less power transfer from the amplifier. As a result, the speaker will not play as loud when it's "warmed up" as it did when it was "cold". Some speakers may exhibit 3 to 6 dB of power compression. This means that power compression can have the same effect as taking away half of your PA! End quote |
#5 |
Yeah, Cal's on to it.
If you lose 3dB, your impedance has doubled. Now imagine what that's done to the Qts that's helped you get that flat bass response...
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#6 |
#7 |
-3dB and a doubling of impedance seems like an awful lot from a PTC. Is this a more extreme example of the concept? If so, does someone know a "what you can expect" figure for typical 6"-8" loudspeakers?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#8 | |
Heavily compressed program (or a hard clipped amp) can hit that kind of average, but music with a wide dynamic range has only a fraction of the average power compared to peak. A 28.3 volt sine wave into an eight ohm speaker is 100 watts, this could easily result in 2-3 dB power compression in a matter of seconds. You would be hard pressed to find any music with that much average power, with a more normal 10 dB dynamic range you would need 1000 watt peaks to average 100 watts. If your "typical" speaker is driven from an un clipped 100 watt amp, the average power is only 10 watts from music with a 10 dB dynamic range, virtually no power compression would take place. |
#9 |
[QUOTE=
If you lose 3dB, your impedance has doubled. Now imagine what that's done to the Qts that's helped you get that flat bass response...[/QUOTE] I find that adding 10% to the port length helps to combat the upward shift in tuning/ Fs/ Qts due to Voice coil heating on my PA speakers. I also get the pole piece vent as close to the port as possible/ or pipe it there to help with VC cooling.
JEREMY M_________________________________ I like it loud, BUT NOT TOO LOUD!.... Hey do you hear that high pitched ringing sound ? |
#10 |
Thanks, weltersys. There was a recent thread concerning rated speaker power here and I don't believe power compression was brought up. I think the two threads provide a good summary of the situation.
| Measuring Output Impedance of Power Supply | korneluk | Tubes / Valves | 21 | 27th December 2010 09:58 PM |
| Transformer reflected impedance games? Overspec'd output power? | flysig | Tubes / Valves | 1 | 23rd May 2009 11:27 PM |
| Possible to design a high-power class D amp with a low output impedance? | 454Casull | Class D | 2 | 23rd February 2009 07:33 PM |
| Tube amps, power and speaker impedance | Klimon | Tubes / Valves | 3 | 11th January 2007 07:32 AM |
| High output impedance amplifier power | 454Casull | Solid State | 6 | 13th February 2005 08:25 PM |
| Page generated in 0.10255 seconds (77.00% PHP - 23.00% MySQL) with 10 queries |
