Old 1st May 2011, 04:25 AM   #1
benb is offline benb  United States
Default What is/was this stereo speaker design and wiring called? (this is NOT biwiring)
I recall many (at least 15) years ago reading of a "new" idea in stereo speakers that gave "better" imaging or had some other characteristics that allegedly made it an improvement over "regular" stereo, and I'm hoping someone can tell me what it was and where I saw it. As best I recall this was described in a magazine article - it might have been Audio Amateur or Speaker Builder, or might have been in a more general, wider circulation magazine like Popular Mechanics.
Each speaker has two identical drivers side-by-side with their centers about six to eight inches apart (perhaps the distance between human ears?). These would have been midrange/treble or perhaps even fullrange drivers. Each amplifier output has two cables, each going to one of the speakers. The left driver in both cabinets is connected to the left channel, and the right driver in both cabinets is connected to the right channel.
Thus each channel's signal came from both speakers, but from slightly different locations because of coming from drivers in different positions.
Does anyone remember this? It was apparently not the advance in stereo the article claimed, as this was the ONLY time I read about or heard of it.
Any opinions on what a setup would sound like and its value or lack thereof would of course also be welcome (as if I could stop anyone here from expressing such opinions).
Old 1st May 2011, 04:50 AM   #2
TerryO is offline TerryO  United States
TerryO's Avatar
I may be mistaken, but it appears that the idea was an attempt to create a sort of Binaural speaker system.
Binaural is recorded with a dummy head (No, not mine!) where the mic's are placed in the same position as a person's ear's would be. Listened to through good headphones, it is astonishingly life-like and just about ruins your desire to listen to a conventional system ever again.
This isn't "the-middle-of-your-head" effect, like most conventional sources through headphones seem to create. The sound can be perceived all around you with correct spacial effects, etc., it's quite an experience.
I can't imagine how the system you've mentioned could actually work very well, but then again, I may be completely wrong.
Best regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 1st May 2011, 05:46 AM   #3
sofaspud's Avatar
Maybe you were supposed to press your forehead against the baffle?
Popular Electronics left us ~10 years ago, but I don't recall anything like what you describe. It also doesn't seem to me to be something Ed Dell would have in his magazines. I'm at a loss imagining just what would be accomplished with that setup. Someday I might hook 2 pairs of Minimus 7s up and listen to what happens.
But I'm with TerryO. I may be clueless and you're on the trail of a lost treasure of audiophilia.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 1st May 2011, 06:10 AM   #4
GM is offline GM  United States
GM's Avatar
'Sounds' like Polk's original SDA system which was really impressive to my ears, but happened to be released about the time cheaper HT surround systems took off, making it an expensive marketing flop even after it was upgraded to a full surround sound bar, another great idea that came along before its time: http://www.polkaudio.com/downloads/w...WhitePaper.pdf
Hmm, maybe not such a flop long term, I see the SDA sound bar has been resurrected/improved..........must go audition one.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st May 2011, 07:32 AM   #5
sofaspud's Avatar
Here's a site dedicated to the Polk SDA models. The more I read this magazine article, the more it appears to be what the OP remembers.
Old 1st May 2011, 08:07 AM   #6
sbrads is offline sbrads  United Kingdom
I remember playing around with other speaker/wiring arrangements that seemed to add space without losing the usual stereo localisation effects. It was 2 extra speakers wired in series placed just behind and each side of the listener, fed from the the 2 live L/R speaker signals, so effectively they were fed by the L-R difference signal, so they received stereo information only. It worked quite well, but the volume needed to be balanced so that you could only just hear these speakers - I used a series resistor. It was called the Hafler arrangement.
Old 1st May 2011, 11:58 PM   #7
TerryO's Avatar
I did a number of those in the 70's. On some recordings they were quite good. A poor man's surround sound...well, sort of
Wire's cheap and it's fun to do, maybe I'll set one up with Lava lamps and a color organ just to show the kids what they missed!
Best Regards,
TerryO
Old 2nd May 2011, 12:31 AM   #8
TerryO's Avatar
GM
I had forgotten about the Polk SDS speakers, as they came out about the time when my wife and I were starting our family.
Never really looked into them, as I remember wondering exactly how they did a crossover for an application like that.
Good Catch Greg!
Best Regards,
Terry
Old 2nd May 2011, 04:43 AM   #9
This is good stuff. I have such a vague memory of this that it may have been that magazine article I remember reading, though I still wonder if it might have been something else.
Old 2nd May 2011, 04:59 AM   #10
49 - for the 16th time
c2cthomas's Avatar
That pretty much happens to me on a daily basis. That's why guys have wives around - they remember everything............
'N if they don't remember it all they need to do is call up one of their gal friends and rehash one of their old chat sessions.
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Wiring two stereo channels to one sub? ancorp Car Audio 7 22nd December 2010 03:54 AM
Wiring mono(2) to stereo Hengy Construction Tips 3 15th October 2009 06:01 AM
What is this Amp design called? packer Solid State 2 1st March 2009 12:11 AM
stereo/mono WIRING CG_25 Instruments and Amps 23 13th August 2007 08:09 PM
Wiring stereo plugs. Valerie Everything Else 1 13th November 2003 05:59 AM
Page generated in 0.12914 seconds (81.51% PHP - 18.49% MySQL) with 10 queries
