Hello.
I have some drivers and crossovers that at one time were part of a kit. Not sure if from Zalytron at the time. The drivers are a pair of C88-6 and a single C23 tweeter. The crossovers I'm not sure how to interpret. I have attached pics and what i was able to sketch out for a schematic (can't read the resistor values on them and was not wanting to desolder to measure at this point). Here are links to the driver spec sheets.... ACCUTON C²88-6 ACCUTON C²23-6 Appreciate the help in figuring out the crossover and what will be a suitable box. Anyone with such experience? Last edited by gruvytune; 1st May 2011 at 04:20 AM. Reason: Add pics |
#2 |
ehh, are you asking where to connect drivers on xo board ?
#3 |
no. that is easy to figure out as they are marked. I will have to figure out though what the polarities are to be since one is 3rd order and the other 2nd order filtering?
More interested in someone suggesting cabinet schemes and possible interpretation of the crossovers and if anyone has used such drivers this way. Thanks |
#4 |
but where did the crossover come from? sounds like youre approaching this all backwards. first you should make a suitable box and then a crossover to match.
If the crossover is part of a design you must make the box according to those specs. |
| Advice on possible setup, DTQWT | caz | Multi-Way | 0 | 23rd April 2011 04:05 AM |
| Accuton C95-T6, advice wanted | Fred75 | Multi-Way | 20 | 2nd February 2009 11:18 AM |
| need advice on system setup | vasdef | Car Audio | 3 | 5th May 2008 03:02 PM |
| Help and Advice for setup | mugglewump | Multi-Way | 5 | 10th March 2006 04:26 AM |
| A new setup, advice wanted | jgunn5066 | Tubes / Valves | 1 | 27th June 2005 09:19 AM |
| Page generated in 0.07930 seconds (72.90% PHP - 27.10% MySQL) with 11 queries |
