Old 30th April 2011, 07:24 AM   #1
Shaun is offline Shaun  South Africa
Shaun's Avatar
Default 4-way: Please comment on this proposed prosed
My crazy friend wants to build a 4-way. We have this thing where he gets the itch, I design, and he goes off and builds it.
Now he wants a 4-way. I have the following drivers on hand:
Morel MDM-55
Hi-Vi D6.8
Hi-Vi M8a
I'm still looking around for a nice small ribbon tweeter to match.
The aim here is not the utmost accuracy, but rather a smooth, romantic sound.
Any ideas on whether this combo will work?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 30th April 2011, 11:36 AM   #2
AllenB is offline AllenB  Australia
You can only do your best Smooth and romantic? Has your friend considered a fullrange driver?
Old 30th April 2011, 02:27 PM   #3
tinitus is offline tinitus  Europe
strange choise of drivers
woofer is rather small for a big 4way
If you insist on 4 drivers, think 2.5way with supertweet
its possible
and it doesn't have to be complicated
but still not easy without experience
Old 30th April 2011, 03:21 PM   #4
kipman725's Avatar
Send a message via MSN to kipman725
to me a 4 way should have a 15" woofer, otherwise what is the point over a 3 way? 4 way also alows the usage of drivers with relativly narrow usable bandwidths but excelent properties in the usable range (like dome midrange). I heard a dome midrange speaker (NS1000M I think) once and it had and the midrange was amazing, mainly in that no matter the position in the room it sounded good showing excelent dispersion.
CHR-70+Subs
Old 30th April 2011, 03:55 PM   #5
Shaun's Avatar
Thankfully, I don't have that problem with him.
I could probably double up on the M8a's. Driver "choice" is dictated by what's available to us, mostly.
I know it well. I owned a pair once.
Thanks for the comments so far. Seems like I'm not thinking big enough, as far as concerns the woofer. Will look into getting something bigger, but I suspect that 12" will be the max he'll go for.
Shaun Onverwacht
Mike's Proposed MTM Mike C Multi-Way 34 5th December 2007 09:33 PM
Opinions on proposed design? leadbelly Multi-Way 13 18th September 2006 09:16 AM
Need comments on a proposed sub design cdwitmer Multi-Way 16 23rd August 2004 09:56 AM
proposed 833 design James D. Tubes / Valves 0 25th March 2004 12:42 PM
Page generated in 0.08025 seconds (72.34% PHP - 27.66% MySQL) with 10 queries
