Old 28th April 2011, 12:39 PM   #1
Default Bi amping required active crossovers?
or not. I've read somewhere on the web where people said it is very bad to have two separate amps drive woofers and tweeters individually feeding to a preamp without using active crossovers.
I plan to have one amp drives my JLB 2235H woofers passively crossing at 400hz and another amp drives my Altec 2440/horns feeding onto my Van Alstine preamp. Just want to ask the question before I ruin anything by doing it this way. Thanks.
Old 28th April 2011, 12:49 PM   #2
AllenB is offline AllenB  Australia
If the tweeter/woofer have passive crossovers then there is no problem.
Old 28th April 2011, 01:02 PM   #3
there is confusion in the use of the term "Bi-amping".
Here in the UK we see that as using two amplifiers to feed the same signal to the two halves of a passive crossover speaker that has dual (or triple) input terminals.
Some countries (US) mean active speakers, using an active crossover to split the signal before the amplifiers and then direct connecting each amp to it's respective driver (speaker).
You are required to read the paragraph and from the context, determine which version of Bi-amping is being referenced.
regards Andrew T.
Old 28th April 2011, 02:52 PM   #4
Yes - using two amplifiers to feed the same signal to the two halves of a passive crossover speaker that has dual (or triple) input terminals.
this is what i am doing. thanks.
Old 28th April 2011, 02:53 PM   #5
I will try this weekend. Thanks
A couple of questions re: bi/tri amping, electronic crossovers EmergencyDpt Multi-Way 17 21st December 2008 09:18 PM
Bi-amping with or without active cross-over? klitgt Multi-Way 11 24th December 2005 05:28 PM
bi-amping through passive crossovers ultrachrome Multi-Way 4 31st March 2005 01:14 AM
bi-amping (active crossover) keyser Multi-Way 16 28th January 2005 09:03 PM
Page generated in 0.07391 seconds (74.39% PHP - 25.61% MySQL) with 10 queries
