I have a speaker with the ScanSpeak 7" woofer that has the carbon fibre impregnated paper cone. The dust cap fell off recently. I tried searching online to see what kind of glue I should use to glue it back on, but can't find anything definitive. Can anyone here help?
#2 |
Hi fishline,
i have no experience with woven carbon fibres ... most 2 component epoxy glues can be mixed in a way to stay somewhat flexible (strangely often by increasing the share of the component called "hardener") Such an epoxy "soft mix" would be my preferred attempt after cleaning the two parts at the contact area. You may try the consistency of the (dried) glue on a piece of paper first. It should stay a bit plyable, not that hard and brittle consistency which is typical for the usual epoxy mix. For canny application you may use a "Tai Stick" e.g. or a toothpick. But i am sure there are more "glueing experts" in here and we will find further proposals ... Last edited by LineArray; 26th April 2011 at 07:19 PM. |
#3 |
Well, I use just about anything handy for dustcaps. If you're not sure of accurate placement first time, then put the cap in place, then run thin superglue around the joint. If you're more confident, impact adhesive, epoxy, or as you have a paper based cone, even PVA. As Oliver said above though, don't use too much, and apply with a cocktail stick or similar, then put a weight on the cap to hold it down whilst it sets. I use an old 1 1/2" socket. Any minor glue runs can be smoothed with a wet fingertip.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Normal speaker glue is made by a company called C P Moyen and is just called moyen by those in the trade. It is a high strength rubber cement. Using a rigid glue may cause the cone to crack where the glue saturates the fibers.
Moyen has a large number of volatile organic compounds that evaporate during drying. That way it leaves a glue joint that flows well but weighs almost nothing. It is also black the favorite color for loudspeaker drivers. You can't buy the glue directly in small quantities directly, so a number of folks repack it in small tubes. However as some folks are going greener a new glue has appeared that is a modified form of what woodworkers call "White" glue also known as Elmers or PVA! This glue remains a slight bit flexible after drying. So if you want to try another glue I would use yellow carpenters glue. The trick is to place the speaker on a lazy susan then place the dust cap on the cone. Then place a weight on top of the dust cap. About 50 grams or 2 ounces should do. You spin the speaker as you apply the glue bead to get that nice smooth look. Then the hard part is not touching anything for 24 hours. |
#5 |
When the dust cap on one of a pair of Energy Connoisseur C-2's I had came off (out of warranty) I called (the old)* Energy co and they told me use "Seal All" which is a fairly high VOC sealant in a tube. Very common in automotive shops because it's impervious to gas and oil when cured, so should not be hard to find. A bit tricky to work with but with some careful positioning it worked and it's been 10 years since. Poly cone speaker.
* Since being bought by Klipsch, I wouldn't expect any decent level of service from Energy ... I had a sub delivered with no power cord ... a simple problem ... and it was not a good experience. They wanted me to box it up and ship it across the country, and wait for a replacement; that solution took 10 days to come up with, after concluding they could not possibly just mail one out, and not until after I was told by one service tech over the phone that it was "impossible" to not have a cord in the box, and implied I was lying (over a $3 IEC cord, yet). I just bought a new cord, and put them on the "Never Again" list, and naturally I share the story whenever appropriate, because apparently that's how they like it. I really did consider boxing it and costing them $150 for shipping both ways, but even with a company I no longer want to do business with that seemed too stupid an exercise to go along with.
" ... In theory, there is no difference between theory and practice; In practice, there is. ..." - Chuck Reid Last edited by Johnny2Bad; 26th April 2011 at 10:19 PM. |
#6 | |
#7 | |
Recently we had to clean failed plating out of the magnet gaps out of 144 tweeters. A real pain in the... Oh yeah just out of warranty. |
#8 | |
#9 |
Ah you understand the problem. All of the above plus stainless steel scraper. Interesting enough the folks I bought them from were using them and did not notice that about 1/3 of the tweeters had enough plating gunk keeping the voice coils from moving properly! Levels were about 6-10 db down at a few K!
| How to remove a dust cap | kach22i | Construction Tips | 6 | 27th January 2011 01:04 PM |
| Do dust cap cover have a sound | xecluded | Full Range | 3 | 20th April 2010 04:43 PM |
| Peerless dust cap removal | ashok | Multi-Way | 11 | 25th June 2007 02:08 PM |
| Dust Cap Replacement | Leoken | Subwoofers | 4 | 23rd August 2006 04:01 AM |
| How i replaced my dust cap... Vol 1 | speekergeek | Multi-Way | 10 | 31st October 2003 03:20 AM |
| Page generated in 0.12023 seconds (80.56% PHP - 19.44% MySQL) with 11 queries |
