Hi Guys,
I've got a copy of LspCAD on it's way and also a calibrated, Behringer ECM8000 mic, mic stand and XLR cable - but what do I need to connect this lot up to a laptop ? I was thinking an M-audio Firewire Solo would do the job. Or is there something better or cheaper that would do the job ? |
#2 |
M-audio mobilePre USB is a popular choice.
#3 |
#4 |
Why would it be remotely better for measurements? There isnt a speed requirement here so firewire is pointless over USB. Just seems like a waste of $$$.
You will also need phantom power for your mic. The mobilepre offers that while the firewire solo might not. Many are already using the mobilepre to measure and build with success so there is no need bother finding something different. |
#5 |
#6 |
Without the presence of facts they are just Opinions ! Keep that in mind WRT the (fire-wire,USB).I would do some research on this and not from the same sources.
I use a New M-Audio Fast Track Pro, that I got on eBay fairly cheap.Calibrated ECM-8000,stand,XLR cables,and the easiest software for the Newbie like me was HolmImpulse.The other softwares out there are a bit more complicated so I would recommend you start with the easiest which works well until you get used to the measuring thing for a bit.
~ Have A Happy And Safe Holidays Everyone ~ |
#7 | |
![]() All you need to know is that there are many, many, many succesful speaker design projects that use the mobilepre. Atleast the solo has phantom power so if you are still not convinced then why do you have a thread?? Just buy it and measure, you waste more time and $$$ thinking about then just doing something. Last edited by doug20; 26th April 2011 at 06:48 PM. |
#8 | |
I'm sure lspCAD is going to cause lots of head scratching, but when I was searching for easy to use beginers software, lspCAD seemed like one of the better ones (It seems none are easy to use though). I also like the fact that JustMLS comes bundle with it, so in theory there shouldn't be any problem importing data from JustMSL to lspCAD. Once my software arrives and everything is set-up, i'm sure my next thread will be called "How the F**K do I get this to work ?" |
#9 | |
#10 |
Well it looks like I should have followed my own instinct and not bought the M-Audio Mobilepre.
I can't get it to work in two channel mode and after a bit of googling, I noticed someone else couldn't get the Mobilepre to work in two channel mode with Justmls. I've ordered some more cables to try Justmls in single channel mode... |
| Speaker Building Software and Measurement Equipment, Soundeasy, Behringer, Ashly,Etc. | sbrtoy | Swap Meet | 6 | 14th March 2011 04:22 AM |
| equipment / new at this | dstew | The Lounge | 8 | 28th March 2010 07:27 PM |
| Your Equipment ! | EdT | Parts | 3 | 27th December 2006 01:16 AM |
| Test & Measurement Equipment for DIY Designers | dgardner | Solid State | 15 | 26th July 2005 03:24 PM |
| Does anyone saw this equipment before? | Sunsun22 | Parts | 8 | 14th October 2004 07:41 AM |
| Page generated in 0.10613 seconds (77.66% PHP - 22.34% MySQL) with 10 queries |
