I'm building a version of 'Rabbitz' crossover detailed here. I'm building a second pair with this design. There is polyfil on the rear baffle & sides which I'm certain will touch components of the x-over. Is this a problem ? Are the resistors likely to ignite the filling material ? Also, are there ways to prevent it ? Any help will be most appreciated, thanks. Cheers. |
#3 |
I am not sure if the resistor will set fire but I do have some residual glue of my 3.3ohm resistor on the tweeter xover and if I play really load on some recordings, I could see smoke from the glue material.
#4 |
Most fibre fill materials should be fire resistant as they are designed to be used in furniture, and as such, in most countries have to conform to quite strict standards. Take an offcut outside, and try setting fire to it with a match. It will probably just smoulder, then go out as soon as the flame is removed. If not, allow lots of clearance, or buy some different material.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
I'd've thought that, if the resistors are getting hot enough for that, you should get some aluminium clad ones, or add a small heatsink.
Have you actually tried the crossover? How long can you hold your finger on the resistor before it hurts? Some resistors get hot, but the first crossover would be putting most of the power through the woofer, so I'd really doubt the resistor will get hot at all. Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#6 |
Simply use larger wattage resistors. You can parallel several resistors of higher ohm value to obtain the value needed. Also mount the resistors so that they have air flow on all sides of them. If the resistors are getting too hot then the design is frankly bogus.
#7 |
Thanks for the ideas and thoughts. I asked the question to be reasonably safe while attempting this. I've decided to go with:
* higher powered resistors * use velcro to hold the polyfil securely in place so theres very little chance it it coming in contact with the x-over Once its complete, I'll post pictures if it will help other diy'ers. Also, looking at the 2 circuit diagrams can somebody please help me understand what kind of power will be taken up by the resistors. My drivers are standard Vifa P13's with Vifa XT25-04. Thanks. |
#8 | |
If you lose sleep over it, add a little cage over the crossover. BTW, the crossover is for the P13/D27TG and will not work with a XT25TG tweeter.
No longer DIY active |
#9 |
I would expect most artificial fibre "wools" to be combustible.
Glassfibre and rockwool are not combustible. But the glue/s used to make them into wool blankets will be combustible. I would expect the glue to be just a tiny w/w proportion of the total blanket weight.
regards Andrew T. |
#10 |
Thanks for the support. The series x/o is going to a P13/D27 design. I'm doing a second P13/XT using 'Sheldon Stokes - quadesl.com' x/o and mixed the two up in the post.
Its reassuring to know your experience with the resistor. |
| help, hot resistors | Ryanschmidt224 | Multi-Way | 156 | 5th June 2011 05:20 PM |
| How hot may resistors run ? | Bernhard | Parts | 10 | 14th April 2009 02:13 PM |
| F2 running hot(how hot is hot?) | Aron | Pass Labs | 10 | 13th February 2009 03:42 PM |
| Wave av-8 hot hot ?? | adharvey | Tubes / Valves | 13 | 7th October 2003 07:32 PM |
| Page generated in 0.11475 seconds (72.76% PHP - 27.24% MySQL) with 10 queries |
