This time I’m going to share some measurement studies I have done on a test loudspeaker. I set up this loudspeaker to see how my DEQX active-crossover pre-amp behaves. For those who are not familiar with the DEQX HDP-3 pre-amp, here is some reading on the subject: DEQX High Definition Audio In short it has the following capabilities and can be described as follows:
The DEQX unit is one of the more advanced equipment to use when going active, but there are of course others who does similar if not identical stuff like the miniDSP, Holm Acoustics DSPre 1, Beringher dcx2496, Ground Sound and more. There will be a lot of pictures and measurement graphs etc. and I hope DEQX owners and other people who are interested in going active with similar technologies will find something interesting and useful in this thread. Please, feel free to comment and discuss. Why go active? Personally I think an active setup like the DEQX is as fun as doing a passive loudspeaker design, but I realize by reading many audio forums that there are different opinions which way to go – active vs. passive. My opinion is why not both? Both have it strength and weaknesses and when used right, they both can sound great. Is it easier designing an active loudspeaker using DEQX? I would say yes and no Yes, it’s easier to get started with a setup like DEQX with its integrated measurement hardware and software capabilities and to get some fairly decent results. No, the same rule of physics applies to an active setup as to a passive one. By that I mean you have to consider and deal with baffle step, baffle diffraction, driver distortion and enclosure shape and design as you would have to do in a passive design. Both an active and a passive design require you to have a decent knowledge about your loudspeakers driver limitations and capabilities. To achieve good or great results you need to have some experience about building loudspeakers. Because the measurement software supplied with the DEQX is a bit rudimentary, I would say that you should have a separate measurement rig to verify your results with. It also requires you to have fairly high computer knowledge since the DEQX isn’t just a stereo equipment, it also requires you to use a computer to configure it. To sum it up, I would recommend the following when using the DEQX:
For someone who is not that experienced in designing loudspeakers, the chances of getting a loudspeaker to sound OK is higher with a DEQX system, than building a passive loudspeaker without experience and/or measuring equipment and software. That’s just my own personal reflections Picture 1: DEQX HDP-3 Preamp Processor (front). Picture 2: DEQX HDP-3 Preamp Processor (rear). Next, measurement setup and equipment…….. |
#2 |
#3 |
Hi chaparK
Thanks for your input! You're right; I was pretty vague in my description. It is not always easy to express yourself with nuances of another language. I meant the overall concept. One advantage of a passive design is for an example that you do not need extra amps and cables = cheaper. Passive components in the filter also interacts with the driver and changes for an example the Qts value for a driver and thus changes the box size and tuning and can be used to tailor the design to your needs or liking. Likewise using different types of caps etc. can tailor the sound characteristic and your sound preference to some degree, although there are different opinions about this matter. As I said, I think both versions are equally fun to work with, but in my experience its how they are used in a design that determines whether they sound good or not. I hope I make some sense? |
#4 |
Good start - Looking forward to the rest of the write up!
#5 |
Hello gonir,
Thanks for sharing! Great start to an interesting subject, especially for those of us that don't or have not tried active crossovers. When I think of active crossovers I think of them either for low crossover points, ie. for subwoofers and or multi-way crossovers, ie. 4-way or more systems. And or use active as a tool to hear a high order crossover vs. low order passive. Now in a 2-way system it would be interesting to compare active and passive. The U16 and RS28a are good drivers for a 2-way. Were you planning on building a speaker with these or were the drivers dedicated for testing purposes? Thanks. |
#6 | |||
Hi Gornir (and everybody!). Thanks for answering my question, and thanks for the post in general!
IMHO, the big advantage of passive systems is that speakers and amps are not 'married' forever. So one can buy a sound system at a time, then upgrade to better speakers at a later time and keep the original amp. Meanwhile active systems are more integrated. For example, if the filtering and the amps share the same power supply and the same chassis, then it's going to be harder to upgrade the speakers separately. I'm looking forward to reading your next posts! chaparK |
#7 |
No, I wasn’t planning on building a design using those particular drivers. I just happened to have them available at the moment.
In my opinion the tweeter is of a quality which would be justifiable in a design with the SEAS W16. I’m thinking perhaps about doing such a design later this summer and I might doing both a passive and active version of it, just for fun
#8 |
Measurement setup and equipment:
This post covers a short description of the equipment and configuration used in the test. Pre-amp processor and active cross-over:
Amplifiers:
Loudspeaker drivers and enclosure:
Measurement equipment (for verification):
Interconnects:
Cross-over filter and correction settings: The following general DEQX settings are used in the test:
Next, measurements…….. |
#9 |
Could you comment on the steep linear phase slopes used. Any draw backs? I have wanted the DEQX for 4 years now. I have the DCX, MiniDSP, Hypex DSP solutions and Im just waiting for the best DEQX deal. I can do a 60dB slope with cascading functions on the MiniDSP but I do not think I can do a linear phase Slope
![]() I look forward to your measurements. |
#10 |
Ev dx46 Doug!
| iPhone App for loudspeaker measurement: who wants to try ? | Fabien Lefebvre | Software Tools | 42 | 6th August 2010 02:08 PM |
| Loudspeaker measurement using SMAART live ? | Empee | Multi-Way | 3 | 12th August 2009 03:50 AM |
| Sound card for loudspeaker measurement | preiter | Everything Else | 8 | 13th August 2007 12:32 AM |
| Loudspeaker Quality Measurement | dm1179 | Multi-Way | 1 | 14th June 2007 07:57 AM |
| Easy Loudspeaker Measurement System Set Up | hongrn | Multi-Way | 3 | 24th July 2006 08:56 PM |
| Page generated in 0.14335 seconds (85.00% PHP - 15.00% MySQL) with 11 queries |
