Old 24th April 2011, 01:54 AM   #1
Default help, hot resistors
Hello,
This is my first speaker project...and pretty much my first electronic project... so bear with me for a bit... but anyways i'm building this...
1.618 - DIY 3-Way Hi-Vi Tower Loudspeaker Project
I believe i have everything wired correctly but the resistors get burning hot, can't even touch them for a second, in a matter of a minute if i crank my stereo up.
The receiver i'm using is 75w/channel
I have 3 questions
Do I need to mount a heat sink to them?
Are they supposed to get that hot?
If i am not running the intended speakers that the crossover was built for could it cause the excess heat? (I am running an old cheap system to proof out the crossover before the real speakers)
Thank you
Old 24th April 2011, 02:05 AM   #2
Speakerholic
Cal Weldon's Avatar
It's not that expensive to up the resistors to 20 watt from 10 watt.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 24th April 2011, 02:22 AM   #3
what difference will upping it to a 20w be? Will it have an effect on the power?
Old 24th April 2011, 02:35 AM   #4
Speakerholic
Cal Weldon's Avatar
It means they will handle double the power and will run cooler for the same input.
Old 24th April 2011, 02:49 AM   #5
thank you,
Should i be running a heat sink? right now i just have them suspended in air, im trying to avoid burning my house down
Old 24th April 2011, 03:12 AM   #6
Speakerholic
Cal Weldon's Avatar
I've not seen resistors mounted to a heatsink in a speaker. People usually up the wattage of them so there's no problem.
Old 24th April 2011, 03:18 AM   #7
dewardh is offline dewardh  United States
No. Did you use the resistors specified in the parts list?
Old 24th April 2011, 04:34 AM   #8
godfrey is offline godfrey  South Africa
It is a bastard of a crossover. With all those L-pads, the resistors are probably consuming more power than the drivers. I'm not surprised they get hot when you crank the volume. Heatsinking is probably a good idea, if there's a sensible way to attach the resistors to the sink.
Old 24th April 2011, 06:17 AM   #9
ya, i copied the parts list and bought those exact same pieces he had listed. What causes the resisters to get soo hot? I know that when you restrict current it creates heat and all that, i just wouldn't expect soo much. I'm assuming since im using all the same parts listed i did something wrong. I am cautious about just upping the wattage because I don't want to sidestep the real problem by fixing something else.
Old 24th April 2011, 06:25 AM   #10
I do not know what was the reason to pad the woofer
down ...
It seems odd to me. Maybe there were problems, which
should have been solved in a different way.
Possibly the rolloff of the woofer's low pass did not match
the desired result and the constructor could not do better
than using an L-pad.
The resulting Q of the woofer rises, calling for a
different alignment of the enclosure: Maybe the current
enclosures alignment relies somehow on that modified
driver parameters.
This is IMO not a design which should have been
communicated as a building plan to be followed by
others anywhere outside the constructor's workshop, sorry.
It can be - at best - accepted to be an intermediate
state in some development.
Oliver, RFZ believer (?)
www.dipol-audio.de
How hot may resistors run ? Bernhard Parts 10 14th April 2009 02:13 PM
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 03:42 PM
Hot hot ouch - rectifier Nordic Parts 9 8th October 2005 07:00 PM
How hot is too hot for a transformer ? haenisch Pass Labs 17 3rd January 2004 11:51 AM
Wave av-8 hot hot ?? adharvey Tubes / Valves 13 7th October 2003 07:32 PM
Page generated in 0.10209 seconds (77.81% PHP - 22.19% MySQL) with 11 queries
