Diy speaker driver project going on.. - diyAudio
Old 8th August 2003, 06:48 PM   #1
Send a message via ICQ to Otherwise
Default Diy speaker driver project going on..
I mentioned before in diy driver thread that I would have a pair of Monacor sp-200x lying around. So, the project has started, here's two pics about the frames. I took em from 5,25" car speakers. Sp-200x's cone is quite deep so the frames needed lifting rings (where the surrounds are glued on). Magnets are from sp-200xs. Monacor's voice coils seem to be of good quality, they have some holes in them and the linear displacement is about +/- 2mm.
Old 8th August 2003, 06:54 PM   #2
Old 8th August 2003, 11:26 PM   #3
tom1356 is offline tom1356  United States
What are the goals for your project?
Please keep us posted on your progress.
My "cult-like" following is accepting applications.
Old 10th August 2003, 11:00 AM   #4
I put more pictures to my homepage. The almost finished driver sound too good
project page
Old 10th August 2003, 03:06 PM   #5
stokessd's Avatar
I would love to see some measurements of the driver when you are finished. I've often toyed with the idea of building a driver from vendor parts.
Sheldon
Old 10th August 2003, 06:16 PM   #6
.. and I would love too to see measurements! Unfortunately I don't have any good microphone yet
Although I did install speaker workshop. I understood that simple measurements could be done just with it, a microphone (panasonic,monacor?) and a soundcard? But we'll see if I have enough inspiration for learning to use spk workshop..
Old 10th August 2003, 06:23 PM   #7
claudio is offline claudio  Italy
claudio's Avatar
Default SW
maybe this site could help you out in using Speaker Workshop.
http://planeta.terra.com.br/educacao...negro/english/
Claudio
Old 12th August 2003, 01:53 PM   #8
I measured parameters, they don't differ very much. I was expecting worse Qes (took the ferrofluid away) but it seems to be quite same. Vas is very approximate due to my poor test box.. Suspension is now stiffer and the cone is about half the weight it was.
Fs: 82 Hz
Vas: 2 L
Qts: 0,54
Qes: 0,67
Qms: 2,88
Monacor original
Which is best choice of driver for Home Theater speaker 5.1 DIY project? langtuhanoi Multi-Way 5 28th September 2008 03:32 PM
Need help with choosing speaker driver for bookshelf project sumacSK Multi-Way 1 11th February 2007 04:54 PM
driver/project ideas for AR x-over? fazman Multi-Way 0 30th January 2006 08:46 PM
driver for hartsfield project puggy Multi-Way 3 7th April 2003 07:03 AM
mtm versus tm driver recommendations on project with $500 driver and xo part limit gsattler Multi-Way 4 20th May 2002 05:54 PM
Copyright 1999-2017 diyAudio
