Active high dynamics/SPL & high performance loudspeaker system for my living room…! - Page 6 - diyAudio
Old 16th December 2011, 07:32 PM   #51
Robert GS's Avatar
Hi Flemming,
Thank you for the nice words
NO NO - they are NOT finished, but I managed to lacquer the front panels - that's all. Maybe I will have a little time over between Christmas and New Year...
The drivers was only mounted in the boxes without the front panels back in May and only for a few days... I can't really comment on the sound quality based on these premises. Furthermore the setup only had a quick and dirty measurement and optimization - it really lacked a better analysis and fine tuning, but I didn't wanted to use the time for it as the loudspeaker wasn't finished.
I have pass on the comments on TLP-150H sound quality till the loudspeakers are finished, optimized and fine tuned....
There is still a lot of paint job to be done - not my favourite hobby
About the crossover point between 10" and 6" - well I think it will be doable around 400Hz or so. The Eighteensound 6NMB420 has reasonable level do to about 250Hz in the MDF boxes - I have to be careful when I make the setup here as the 6" has an acoustical slope around 12dB/oct from 250Hz
diyAudio member pk should be able to tell you about sound quality of TPL-150H. You might even ask him for a demo in his basement - he lives in Jutland just like you
Robert GS
GroundSound.com Active Sound - Active Listening
Digital Crossovers, Power Amplifiers and DIY modules
Old 1st January 2012, 06:00 PM   #52
Robert GS's Avatar
Happy New Year all @ diyAudio
Update... no progress on the loudspeaker boxes
But I managed to get a good start on an exclusive limited series of the new Chassis II 1500 configured with Digital Crossover DCN24 + 4 x PA6CC + PSU12SA + 1500VA toroidal transformer. In other words a might powerful 4-way active amplifier solution. Dim. 42(H) x 29(W) x 45cm(D) and +40kg! Pictures & description will surface mid/end January on the Ground Sound web.
Robert GS
Old 11th April 2012, 05:04 AM   #53
Robert GS's Avatar
Talking I guess they will be dark red
Finally some small progress...
I hope to assemble the main speakers within the next week if I can find the time
Robert GS
Old 11th April 2012, 05:12 AM   #54
Look forward to seeing the finished speakers... Will make sure I don't ask ay questions over the next few weeks to give you chance to work on them
BTW the XLR connectors turned up yesterday and I'm close to firing up the DCN28 for the first time
Old 2nd June 2012, 01:41 AM   #55
Are they together yet Robert? keen to see the finished result.
Old 2nd June 2012, 05:12 AM   #56
Seems as if the TPL-150 likes red! Very nice project BTW.
We might need to talk about a smaller form factor coolback style amp for my next project, a smaller 3 way nearfield studio monitor with Scan, BG Neo8S and Raal.
Greg
Old 2nd June 2012, 06:55 PM   #57
Robert GS's Avatar
Hi Silent Screamer and all of you.
Well – I have been listening to the nearly finished system for some time now
The corner subs aren’t painted yet – reason later…
See the attached pictures for the latest developments.
The system has been measured and setup via the XOverWizard II advanced software and this has resulted in a reasonable (some will probably say excellent) sound, but I have some issues….
I feel that I have to tweak the TPL-150H some more – like there are some nasty frequencies without being 100% sure what it is. The TPL-150H measured on-axis without filtering - see attachment.
What do you think – has anyone measured the TPL-150H? and close and above 20kHz? What do you think?
Overall the sound and response of the 6” Eighteensound drivers seems to be very good and I have no direct complaints here.
The choice of the Sica bass drivers might be a bit off or maybe NOT. It results in a very nice tight punchy bass and they might have been enough if the enclosure for them had been bigger and ported... Sure would have been
I have actually tested the system without the subs for some time, but it proved that the enclosure volume for the 10” were too small – also seen in the measurements that I made.
Well – I wanted the dual 18” corner subs to begin with – now I am not 100% sure because they sound right but this is totally overkill – when my ears begin to bleed, they barely move and they extend down to 20Hz A year ago I actually tested with a tone generator at 20Hz - scary the wall of my wooden house moved many millimetres at high but not at all full level…!
I have even been thinking of replaced the corner subs by two ported folded front-loaded horns, because this is what I really like the very best when it comes to bass reproduction. Each horn would “only” use one driver and one box in each corner, BUT NO NO NO – this will never happen I want to keep my house standing.
AND my living room is way too small – it can’t absorb the energy, so at high SPL level the room is simply flooded. I have been thinking about damping, but I can’t really come up with a decent solution which will be acceptable to me and my family. And on top of that the system makes many things rattle at the levels where the fun really starts. Am I getting old…?
I am contemplating to just let the new high dynamics system go and reinstall the ScanSpeak towers after a few upgrades – maybe replacing the ScanSpeak dome with a Mundorf AMT1908C and definitely a new more potent Coolback without a digital crossover using the DCN28 to it’s full potential. The current version of the ScanSpeak tower really makes my day and they probably are more forgiving to more music material / quality – so that the overall sound is more like – “easy listening”…. I am getting old – aren’t I ?!?!
Robert GS
Old 2nd June 2012, 07:03 PM   #58
Robert GS's Avatar
Greg
Hi Greg,
Nice red boxes - I really like the deep red colour for loudspeaker boxes...
Maybe I have to repaint the ScanSpeak towers if I go ahead reinstalling them
You are always welcome to contact me about a set of Coolbacks
Robert GS
Old 3rd June 2012, 12:52 AM   #59
Cabinets turned out real nice.
2 x duel 18’s - nothing wrong with overkill that's how I engineer everything
I am currently thinking along similar lines... A TH with single driver in each corner as a 4th way on the DCN28, that way they are only used as required.
Old 3rd June 2012, 08:49 AM   #60
Shaun is offline Shaun  South Africa
Shaun's Avatar
Hi Robert. Excellent project!
Comparing the manufacturer's spec to your own measurement of this driver, there seems to be a discrepancy up above 10kHz: their plot is flat, while yours has a dip. I find that equalising such deviations can introduce problems, rather than solve them. DSP tools are very powerful, but one can over-compensate or, rather, mis-compensate.
My suggestion: do some off-axis measurements and see whether that dip also exists off axis. Alternatively, try smoothing your measurement to 1/3 octave before applying equalisation.
I find that exercising constraint when equalising the tweeter yields good results, usually.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
FR8C 25lt sealed mid-high in active bi-amp system col Multi-Way 0 17th June 2009 12:15 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
high performance but cheap amp rulezzz Solid State 7 15th May 2004 03:30 PM
Building a reference active 3-way speaker for high SPL Ricren Multi-Way 45 13th March 2004 11:10 PM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
