Old 3rd June 2012, 07:38 PM   #61
kipman725 is offline kipman725  United Kingdom
kipman725's Avatar
Send a message via MSN to kipman725
Have you tried constant directivity speakers?
you could install thick carpet in your room that would add some damping.
Great speakers though, red is far cooler than the usual black.
CHR-70+Subs
Old 3rd June 2012, 09:24 PM   #62
Robert GS is offline Robert GS  Denmark
Robert GS's Avatar
Originally Posted by Shaun View Post
Hi Robert. Excellent project!
Comparing the manufacturer's spec to your own measurement of this driver, there seems to be a discrepancy up above 10kHz: their plot is flat, while yours has a dip. I find that equalising such deviations can introduce problems, rather than solve them. DSP tools are very powerful, but one can over-compensate or, rather, mis-compensate.
My suggestion: do some off-axis measurements and see whether that dip also exists off axis. Alternatively, try smoothing your measurement to 1/3 octave before applying equalisation.
I find that exercising constraint when equalising the tweeter yields good results, usually.
Hi Shaun,
Have a look at the attached - Why do you think it's good enough to overlook peaks just because the manufacturer only measure to 20kHz and smooth the "rest". Normally I would say that you have to look to the "break ups" (= heavy distortion) in the upper range of a driver - will normally give some problems further down in the frequency range if not dealt with.
Do any of you diyAudio members have any measurements of the TPL-150H? Also about 20kHz !
I actually sit on-axis and in the setup the peaks are minimized with a few PEQ to avoid any disturbances. I have to say that the sound isn't at all bad - and I will probably be able to tweak / fine tune the sound 20-30% more improvement.
@ kipman 725
NO - I haven't tried constant directivity speakers.
The room is a big room combining living room, dining room, small office space and kitchen - very nice for family activities but not for very high SPL listening levels and I doubt that a carpet will do the trick in this case.
I have a smaller dedicated listening room in conjunction with the electronics workshop and it very very good for listening, but it will not accommodate the High Dynamics system.
I will tweak the system over the summer and see if it does the trick - so that I will keep the system. Otherwise I have the excellent ScanSpeak towers that I can upgrade to perform maybe even better... One thing is for sure, I will never be able to exploit the full dynamics of the current system.
Robert GS
GroundSound.com Active Sound - Active Listening
Digital Crossovers, Power Amplifiers and DIY modules
Old 3rd June 2012, 09:55 PM   #63
Shaun is offline Shaun  South Africa
Shaun's Avatar
If I look at the projects here Hi-End and Hi-Eff loudspeakers system 2 and here Acoustic Elegance • View topic - TD15H + Beyma TPL-150 2-Way Build, it does indeed look like the manufacturer has published very optimistic curves for the driver.
And no, am not saying to accept the manufacturer's data. It is always better to measure. I still suggest, though, that you give it a shot with minimal HF equalisation. Should be easy enough with the tools at hand.
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Old 29th June 2012, 11:08 AM   #64
Busk is offline Busk  Denmark
I have just visited Mr. Gs an heard this system, and I want one :-)
Old 1st July 2012, 06:48 AM   #65
momomo67890 is offline momomo67890  United States
heres my measurements of a tpl TPL-150H its flat all the way down to 1k hz the pic is with xo in place no eq. almost +/- 1db 1/24th
Old 1st July 2012, 11:23 AM   #66
Scott L is offline Scott L  United States
Default response curve
Greetings,
That response curve you posted is similar (but not exactly the same) as to
the Stage Accompany SA 8535. The two drivers resemble each other. I said to myself if I ever lost the SA's, I'd consider the Beyma.
What I did (to tame that very mild peak) was use an in-line single high quality cap, but of course to still use an active crossover. Of course as low as the OP is crossing, a notch should be in better order than a rolloff cap. Then again, that slight variable in response in the over all system may not be bothersome at all.
Old 1st July 2012, 06:35 PM   #67
angeloitacare is offline angeloitacare  Brazil
angeloitacare's Avatar
that is my measurement of the Beyma TPL-150 with wave guide, on axis, at 1m distance :
AV Eikon : finished - Page 2 - Audio Voice Acoustics
Old 16th November 2012, 05:26 PM   #68
johnc is offline johnc
I have noticed a few comments about the frequency response plot on the TPL150H datasheet being optimistically flat. IMO, it looks flat because of the scale of the sensitivity axis being from 20dB to 120dB. If the axis was from 80dB to 120dB, I think the curve would be as jagged as the ones posted in this thread.
Old 29th December 2012, 07:50 PM   #69
SpeakerFrank is offline SpeakerFrank  Germany
Really a nice setup Robert, looks like it sounds worth to be heard!
Old 29th December 2012, 10:53 PM   #70
in my room with no correction it was +/- 2.5db.
FR8C 25lt sealed mid-high in active bi-amp system col Multi-Way 0 17th June 2009 12:15 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
high performance but cheap amp rulezzz Solid State 7 15th May 2004 03:30 PM
Building a reference active 3-way speaker for high SPL Ricren Multi-Way 45 13th March 2004 11:10 PM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
