Old 29th April 2011, 04:13 PM   #11
Robert GS is offline Robert GS  Denmark
Robert GS's Avatar
Hi Peter,
The system is for stereo. The 4 pcs 18" drivers have more than enough headroom I think - so why not tune them low?
I assembled the front boxes today, but I don't have more time for fun today...
I will probably have first impressions tomorrow.
Robert GS
GroundSound.com Active Sound - Active Listening
Digital Crossovers, Power Amplifiers and DIY modules
Old 30th April 2011, 04:42 PM   #12
pk is offline pk  Denmark
Originally Posted by Robert GS View Post
Hi Peter,
Robert GS
Hi Robert,
Thanks for your reply. I will be following the thread:-)
Best regards
Peter
Old 1st May 2011, 09:10 PM   #13
Robert GS's Avatar
Default Initial test – testing the connections
I did make the initial connections test yesterday. A simple setup was created with crossover points at 80Hz, 400Hz & 2kHz. All drivers and amplifiers were connected correct – so that was a good start. I also listen to the setup for a while, but I didn’t like what I heard – the system sounded awful.
This is how the initial simple setup looks like:
But don’t despair it got better later yesterday – I will make a little report tomorrow… time to go to bed
Just one more picture:
Stay tuned - thanks Robert
Old 2nd May 2011, 08:07 AM   #14
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
No wonder it didn't sound good, you've got the speakers in the wrong position!
Old 2nd May 2011, 08:54 AM   #15
Robert GS's Avatar
Ahhhh ha ha - they were placed like this at the initial connection test:
It's a bit better this way
Old 2nd May 2011, 09:02 AM   #16
_henry_ is offline _henry_  Australia
hi robert,
i believe the position compromise the sound. if u moved the speaker next to it, and move forward by 20-30cm, i'll bet will improve.
just my 2˘
cheers
henry
Old 2nd May 2011, 09:44 AM   #17
CCU is offline CCU  Denmark
Send a message via MSN to CCU
Why haven't you countersunk the drivers?
But damn the look impressive
Old 2nd May 2011, 10:54 AM   #18
Robert GS's Avatar
Originally Posted by _henry_ View Post
hi robert,
just my 2˘
cheers
henry
Well - it wasn't the placement - I am used to have a pretty smooth response from my loudspeakers
Just making some crossover points on drivers that measures like this will not make me happy.
As I mentioned in an earlier post it got better later that day. I made a quick setup (15min including measurements) based upon measurements of the horn, mids, and basses, but I was too lacy to measure sub as only one sub is finished. This is the frequency response of that setup (simulated and it will measure like this, if I had made a measurement).
The one sub is only crossed at 70Hz (no EQ) and does a formidable job placed in the corner. It will most likely be much better when both subs are up and running. I have had a customer round for a listen and he was very impressed at this early stage.
I am pretty happy already
Old 2nd May 2011, 11:02 AM   #19
Robert GS's Avatar
The boxes ain't finished - this is only the initial testing. The real front piece isn't mounted yet - both the front boxes and the subs will have an extra front, when I have time for it. Actually I also ran out of damping material - so the 10" driver enclosures has a minimum and the one sub has no damping at all
BUT the system already sound incredible
Old 2nd May 2011, 11:40 AM   #20
Aakilde is offline Aakilde
I support Robert's statement about the incredible sound! -I heard the system yesterday and at a point, I was in doubt whether it was the building or the drivers, which was the moving part.... This system in a 40 Sqm living room will be able to generate whatever sound you would like at whatever level you would wish...
FR8C 25lt sealed mid-high in active bi-amp system col Multi-Way 0 17th June 2009 12:15 PM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
high performance but cheap amp rulezzz Solid State 7 15th May 2004 03:30 PM
Building a reference active 3-way speaker for high SPL Ricren Multi-Way 45 13th March 2004 11:10 PM
Suggestions for high efficiency high SPL kit/design Kanga Multi-Way 50 23rd May 2003 12:52 AM
Copyright ©1999-2017 diyAudio
