Old 22nd April 2011, 03:46 PM   #1
Bill poster's Avatar
Default Damping a drivers frame with putty or similar
If I use grip fill or some form of putty (maybe one that doesnt set) to damp the frame of a driver, what are the benefits and are there any drawbacks? Will it lower the Fs?
Old 22nd April 2011, 10:15 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
benefits:
damps potential ringing
Drawbacks:
could fall off or loosen over time
if solvent based could affect driver glues or materials
It won't change parameters much, if at all, unless you significantly reduce open area.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 23rd April 2011, 12:24 AM   #3
dewardh is offline dewardh  United States
Pretty much pointless. Just magnet mount the driver . . . then the only load on the frame is the almost trivial force from the surround.
Old 23rd April 2011, 12:42 AM   #4
Originally Posted by Ron E View Post
benefits:
Drawbacks:
http://www.bostik.co.uk/diy/product/...lvent-Free/143
In the UK we have Grip Fill, which is a pretty cool product. Its very versatile and can be used to glue/ fill/ seal anything. It doesnt fall off or fall out EVER even after yrs and the yellow tube type is a kind of 'eco' version, so it shouldnt damage plastics or react with other materials. I might give it a try..
Old 23rd April 2011, 01:59 AM   #5
Altec Best's Avatar
Absolutelately waste of time "Not Necessary" IMHO
~ Have A Happy And Safe Holidays Everyone ~
Old 23rd April 2011, 02:20 AM   #6
Ron E's Avatar
Evo-stik Gripfill Solvent Free - High performance, general purpose, solvent free gap filling adhesive
I have heard of using:
http://www.amazon.com/Gardner-Bender.../dp/B000BO8XD6
or:
Plasticine - Wikipedia, the free encyclopedia
Old 23rd April 2011, 03:27 AM   #7
TerryO is offline TerryO  United States
TerryO's Avatar
What I, and many others use, is Duct Seal putty, or if you can't find it, Oil-Based Modeling Clay. Neither one will ever harden, can be reused or removed, and isn't very expensive.
However, it will not lower the Fs of your driver.
[Edit: I see that Ron E has provided a link in the previous posting.]
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 23rd April 2011, 04:56 AM   #8
DJNUBZ is offline DJNUBZ  United States
Dynamat extreme or Roadkill work well for this application. Makes a bigger difference on stamped basket drivers then cast basket. Making a thicker baffle to mount to would be a much more productive way of dampening vibrations.
Old 23rd April 2011, 05:26 AM   #9
frugal-phile(tm)
planet10's Avatar
Don't forget the role something like ductseal can have in improving the aerodynamics of the back of the driver (and thus reduce the bleedthru of time smeared signal getting out thru the cone).
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd April 2011, 05:55 AM   #10
dantheman's Avatar
Dave, can you post your pics of these modifications you've made. I can't seem to find them here.
Thanks,
Dan
My Blog
My Music Recordings
Basket, magnet & frame damping: How to? gnugear Full Range 24 26th March 2008 10:05 AM
FR125s frame/magnet damping Foxx510 Full Range 3 6th August 2007 02:02 AM
8" Drivers for a small U-Frame Tenson Multi-Way 11 7th January 2007 02:27 AM
re-use DCM time frame drivers quiet Multi-Way 3 27th February 2006 03:11 AM
Page generated in 0.10447 seconds (79.41% PHP - 20.59% MySQL) with 10 queries
