I am a true beginner at crossover design. I am armed with edition 4 (1991) of Vance Dickason's cookbook and enthusiasm. I have fountek fr88-ex and dayton nd20-fb-4. Is the following design a good starting point or will it smoke my components? I was trying to cross at 5k. Thanks to anyone who spends the time to look over my attempt.
#2 |
Hey, I'm really not alot of help here, but the 15uf may be too big, and I don't want you to pop the tweeter. I would think 5uf and .25 might be closer. I could not find my copy of cookbook to see how you were calculating, but I plugged the numbers into some online things and could not get the cap much above 8uf, and did not hit 15uf till I went down to 1500. Looks like about 3.2 ohms at 5k.
Get more opinions before you give it much power. Basic config looks fine. Dave |
#3 |
The attenuation of the tweeter is not enough. The FR88EX has 84dB/1m and if you include baffle step 81dB attenuation. The tweeter has 90dB/1m sensitivity.
5KHz is a good point of crossover. Tweeter : you need to remove 9dB with a LPAD 2.2 series and 2.2 ohms parallel crossover 5Khz LR2 : 4uF 0.22mH The woofer I calculate 1mH 4.7uF |
#4 | |
Erratum a schema is better : your woofer values are ok 0.5mH 2uF For the tweeter C becomes 5.6uF
#5 |
Thanks all. I was worried about the tweeter atttenuation but did not know how to compute it properly.
#6 |
Jerome, that is much better than I could ever do as a first shot. Thanks for the lesson also.
#7 |
Ya know. If you wanna really do this "right"/better. www.zaphaudio.com has FR and impedance plots of both those drivers on his site. You could use SPL Tracer to make .frd and .zma files. Then download Jeff Bagby's PCD, free. You could then design the XO based on real measurements.
Now, those are infinite baffle measurements. So, even better would be to simulate diffraction, baffle step, etc. before doing the XO design. It's take quite some effort, but will likely do better than just throwing some calculated values in there. I recently did something very similar for the first time. I can link you to my build thread if you want some guidance on how to go about it. Oh ya, I agree with the above. 15uF to big and 1.2ohm to small. Make the resistor swapable so you play till you have it right. |
#8 |
#9 |
I will spend some time learning how Jerome set up the tweeter circuitry. Tuxedocivic please pm me the link to your build guide. I am a beginner with some good electronics experience. The software may be a bit complex for my current level but I would like to begin getting familiarity with it.
#10 |
I have some years of designing loudspeakers, there are a lot of tips.
I can give you useful links : FRD Consortium http://www.mh-audio.nl/index.asp HOLM Acoustics ARTA Home You should read this first : crossovers Hope this helps. Note : Your set-up works and fortunately the theoretical values are closed to the actual values |
| MINI A: who let the smoke out. | d to the g | Pass Labs | 9 | 28th March 2009 02:32 PM |
| Smoke Machine | keantoken | Everything Else | 0 | 13th April 2008 09:07 AM |
| Smoke or Fire? | Netlist | Everything Else | 4 | 7th May 2006 01:56 PM |
| I let the smoke out. | TerryG | Class D | 16 | 8th November 2005 06:25 PM |
| Up in smoke... | PhaseShift | Solid State | 2 | 3rd September 2002 05:03 PM |
| Page generated in 0.10787 seconds (79.26% PHP - 20.74% MySQL) with 11 queries |
