Old 20th April 2011, 06:41 AM   #1
Default Need speaker A/B switch without common (-) connection
I need a speaker selector A/B switch that does not connect the negative speaker sides together as most of them seem to do. I need to be able to A/B two sets of speakers and two Tripath-type amps which do not work if the speaker negative terminals are tied together.
I bought a Dayton source/speaker switch but the (-) teminals are common making it unsuitable for that kind of amp. I'm afraid they may all be like that. Are there any that aren't?
Shrink to Patient: "Forget the Prozac, you need more Boogie!"
There are only two kinds of music. Good and Bad
Old 20th April 2011, 06:51 AM   #2
sofaspud's Avatar
I made a similar inquiry not long ago. Response was minimal.
I think your best bet may be some good DPDT break-before-make switches.
Unless you can mod that Dayton unit...
Old 20th April 2011, 07:10 AM   #3
I'm afraid you may be right. There are other selector switches, but there's no way of knowing how they are wired and I'll bet they're all like this to save costs. I don't actually mind building something if I have to. I guess I'll draw something up and look for parts. Haven't been parts shopping for a long time.
Design wise, should I be concerned about transients caused by mechanical switching under power? I'd like to be able to switch on the fly but power would probably not be >10 watts or so. I agree with break before make.
Old 20th April 2011, 07:27 AM   #4
sofaspud's Avatar
Lower power probably helps, but personally I'd avoid on the fly switching if possible. If you really want it you'll need to give caution to the amps. I don't know how t-amps respond to being unloaded, even (or especially) briefly. That issue may have been brought up here in the forums at some point. And if power is on break-before-make is not optional I would think.
Speaker protection and common ground ads2 Chip Amps 7 1st January 2011 11:42 PM
Check my SSE's Triode/UL and CFB Switch Connection Junior Tubelab 19 17th April 2010 02:58 AM
speaker connection? Tony.ca Multi-Way 11 21st February 2004 03:58 PM
How to model speaker interaction in common chamber dih1118 Multi-Way 0 22nd September 2003 02:25 AM
Common Source versus Common Drain output stages alaskanaudio Solid State 33 27th March 2003 02:04 PM
Page generated in 0.06834 seconds (73.61% PHP - 26.39% MySQL) with 10 queries
