Old 18th April 2011, 12:57 AM   #1
Default Always check your caps...
For all those people with old speakers that maybe don't sound as good as they used to, check your caps...
Got a pair of Dynaco A25s the other day, things sounds NQR from the get go, one side had LOW treble output. Fussed about until finally realizing I should check the x-over, visually looked OK, checked the caps on the meter.....should be 5uf; one was 6.28uf the other 1.53uf!
I replaced the caps and the sound is back to normal. I can get back to enjoying the A25s.
Richard.
Old 18th April 2011, 11:08 AM   #2
DavidL is offline DavidL  United States
DavidL's Avatar
Richard.
Also a good idea to check the caps ESR. Sometimes the capacitive value is normal but the ESR is way too high which will also cause low treble output.
Old 18th April 2011, 11:48 AM   #3
I hope you replaced those aged NPE's with film types.
Here's a thread about a comprehensive way to measure capacitors.
WT2 owners: A better way to measure your capacitors
Old 18th April 2011, 12:50 PM   #4
Thanks for the suggestion about ESR, I wouldn't have thought to do that.
Replaced the caps with some Bennics I had lying around.
FS: F5 Amplifier Kit - Boards, Heatinks, Power Caps, Input Caps, RCAs, Binding Posts gripracer Swap Meet 16 8th November 2010 03:54 PM
0ne 100uF cap or ten 10uF caps (or two 200uF caps...etc) Hubba Power Supplies 3 15th September 2010 06:13 PM
FS BB OPA660AP, WIMA caps, ROE Caps and other Andypairo Swap Meet 10 13th August 2005 02:46 AM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
ARC pre amp-modded with Kimber caps-anybody used these caps before? croft Parts 34 27th October 2002 11:13 PM
Page generated in 0.07556 seconds (71.92% PHP - 28.08% MySQL) with 11 queries
