I'm in the middle of upgrading my 15's. I'm replacing the foam in the speaker but was wondering what would happen if I put too much foam in the passive radiator chamber of the cabinet. Should I just leave the area devoid of foam or completely fill the area?? Thanks in advance. |
#2 |
Foam?
You mean speaker stuffing like the inside of a pillow? I used the matting sound material with my passive but kept it away from the cone. Passive radiators have quite a long stroke and will compress the stuffing in short order, maybe too much. Since the cone is moving so fast, I'm afraid the stuffing will wear on the cone and could throw it off balance which will put torque on the suspension. You do have the option to zip tie some netting around the frame of the passive, it will keep any loose speaker stuffing from hitting the disc or cone. |
#3 |
If you mean putting more fibrous material inside the speaker cavity in addition to what Celestion originally placed there you will alter the bass characteristics a bit.
It will depend on how dense you pack it etc but the difference between empty and "fully packed" increases the apparent volume by the square root of two i.e. about 1.4. This is the result that Gilbert Briggs obtained experimentally and was the same as the theoretical calculations (James Moir, I think). Now that may not of course be a bad thing. May sound better. But both theory and practice suggest it will have an effect. Try it I guess. Cheers, Jonathan
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. |
#4 |
Thanks guys. I just intended to try and dampen the cabinet down internally as much as I could. So I'll have to experiment and see what happens!
| Celestion Ditton 15XR | singlemania | Multi-Way | 16 | 20th February 2012 07:44 AM |
| Wanted :: Celestion Ditton 15XR Tweeters | roozor | Swap Meet | 1 | 16th October 2009 03:27 PM |
| passive radiator question | krikus050 | Multi-Way | 7 | 5th October 2008 06:53 PM |
| Celestion Ditton 15 or 15XR Crossover | Bennyboyph | Multi-Way | 7 | 4th January 2006 08:26 PM |
| Subwoofer and Passive Radiator question... | WolfmanX | Subwoofers | 0 | 19th November 2002 01:10 PM |
| Page generated in 0.07478 seconds (72.69% PHP - 27.31% MySQL) with 10 queries |
