Old 16th April 2011, 10:44 PM   #1
Default 4 ohm or 8 ohm sound?
Hi all,new here and wondered what your thoughts are regarding ohms vs sound?
I have a pair of Klipsch kg4's that are rated 6 ohms but my amp ..............( yaqin mc-10L) only has 4 or 8 ohms.
What would be best for these speakers and would the sound change?
thanks..gzman71
Old 17th April 2011, 01:41 AM   #2
Jay is offline Jay  Indonesia
No speaker has a flat impedance from 20Hz to 20kHz. So that 6 Ohm is only a "conventional" way to specify it's impedance (it is not minimum impedance either). It will be above 10 Ohm at 20KHz, and could possibly be close to 4 Ohm at around 100 Hz.
Going up and down a little bit with the amp (4/8 Ohm) will not create serious problem.
In general, using 8 Ohm, you will have longer life tubes, worse quality sound, but all is only marginally.
Theoretically, depends on many things, a 4 Ohm tap could give you a better or worse sound, but most of the time better, in bass quality. Whether you can hear it or not, that's the question. I doubt you can. I'll prefer using 4 Ohm.
Old 17th April 2011, 01:51 AM   #3
thanks for the explanation.............i'll try 4 ohm and see how it sounds.
2300 ohm vs 5000 ohm output trans question speakerfritz Tubes / Valves 4 2nd October 2010 10:17 PM
Altec 806A 16 ohm to trade for 806 8A (8 ohm) diaphragms nelsondog Swap Meet 0 7th April 2010 12:32 AM
PHL Bass Midrange 8 ohm vs 16 ohm - same SPL: Why ? tiefbassuebertr Multi-Way 6 28th March 2010 06:14 PM
What's the closest I can get to a 4 ohm load using 3 single coil, 6 ohm drivers? The Paulinator Multi-Way 9 11th May 2004 07:04 PM
Matching my 8 ohm amp to 16 ohm speakers. DocJDG Solid State 3 5th December 2001 01:54 PM
Page generated in 0.06707 seconds (69.20% PHP - 30.80% MySQL) with 10 queries
