3 8" woofers, wiring? - diyAudio
Old 12th January 2002, 08:47 PM   #1
Default 3 8" woofers, wiring?
I've got 3 8" woofers 8 ohms. dc resistance is 6.4 ohms. How can I wire these together to get a reasonable impedance and have all three playing at the same level.
Old 12th January 2002, 09:33 PM   #2
kiwi_abroad's Avatar
Hello Ken,
Bad Luck, Either connect them all in parallel (2.6 Ohm nominal) or all in series (24 ohm nominal) for an equal sound output from them.
Either get another identical woofer, and wire them in a series/parallel combo for 8ohms, or spend some more money and get a good quality amp that will drive a low impedance load without losing its composure.
Another option will be using multiple amplifiers...
Cheers, Adrian
Looking to re-house Tannoy 10" DC and 10" woofers in to other cabinets speedysteve Multi-Way 15 30th September 2008 04:27 AM
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 10:57 PM
Sonus Faber 6.5" woofers and cheap 3" fullrange and misc. Jimmy154 Swap Meet 10 26th December 2007 05:20 AM
"classic" amp and begginners problems (pcb wiring, component values) adi81bv Solid State 15 17th April 2007 10:50 AM
Wiring high Watt sub woofers into home audio systems. Broken_Sight Digital Source 1 8th January 2004 12:28 AM
Copyright 1999-2017 diyAudio
