Old 16th April 2011, 01:10 PM   #1
Bill poster's Avatar
Default best tweeters under $200?
Any recommendations for a shortlist?
Looking at Dynaudio, Scanspeak etc but there are just so many new tweets on the market. Interested in ceramic domes like the Accuton(?). Its going in a high powered 3 way system.
Old 16th April 2011, 01:32 PM   #2
keyser is offline keyser  Netherlands
It very much depends on the exact application. There are many very good tweeters that cost far less. What kind of speaker do you intend to use it for?
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche
Cardioid-like + Waveguide 2-way
Old 16th April 2011, 01:41 PM   #3
Thanks Keyser. Its for a good friend who wants a 3 way set of speakers he can use domestically and as studio back wall monitors, plus he likes dubstep, hence the need for power. I've seen some dynaudio's on ebay and I'm looking at the morel Rohacells for mids. Maybe a pair per side of HiVi W10s for bass duties. I'm aware there are some great tweeters at cheaper prices like the tang band ceramic domes but not sure if they will handle the power, so if you have any ideas it would be much appreciated!
Old 16th April 2011, 02:05 PM   #4
If price really isn't very much of an issue, I'd try the Seas Millennium. Very nice frequency response, good dispersion and great power handling! The Scanspeak 6600 is nice too. I wouldn't use the Accutons - the frequency response could be flatter and smoother. Another option is to simply cross a little higher - depending on what mid you're using. But really, most modern domes have decent efficiency and aren't destroyed that easily.
Old 16th April 2011, 02:35 PM   #5
Thanks! have you heard the new scanspeaks with the pointy tweeters? I think Vifa do something similar but theirs look like nipples lol.
Old 16th April 2011, 02:59 PM   #6
adason is offline adason  United States
adason's Avatar
I use this planar tweeter from HiVi (in 5-way work in progress set) and I am very happy with its sound:
HiVi RT2C-A Planar Isodynamic Tweeter
Old 16th April 2011, 02:59 PM   #7
Yes, I've 'heard' both the nipples and the pointy ones, and they're both very good. The Scanspeak goes louder, but is also several times as expensive. Ultimately it is the total design that makes or breaks the sound of an individual driver. More often than not, the recipe is more important than the quality of the ingredients, provided the ingredients meet some reasonable quality criteria.
Old 16th April 2011, 03:02 PM   #8
Yeah, or this one: HiVi RT2H-A Planar Isodynamic Tweeter
They're used in a pair of $80,000 Ascendo speakers. They sound good and go pretty loud!
Old 16th April 2011, 03:11 PM   #9
Interesting, wd never have considered one of those planar tweeters; will they be ok in a high power studio rig..could I use a pair per side or is that a no no?
EDIT just seen these hivi's, gorgeous.
http://www.swanspeaker.com/products/...sid=52&pid=168
I realise is that the power rating of tweeters is a bit misleading. I heard many recommending this Usher model and saying they are fantastic, go very loud, even tho they are rated at just 15 watts!
http://www.parts-express.com/pe/show...number=276-610
Old 16th April 2011, 03:32 PM   #10
Selenium ST324 Super Tweeter ABS Housing
Since parts express site redesign, spec sheet links that used to work are now broken. Try the mfg...
http://www.selenium.com.br/site/asse..._pdfManual.pdf
This old JBL slot design gets bashed for "diffraction".
All I care is these sound great, everywhere in the room.
Its a far bigger device than it appears in the picture,
but not heavy that you'd start wishing for neodymium.
Strong plastic body forgives some of the magnet weight.
This mentions some cavity to stuff with plumbers putty?
http://www.bottlehead.com/climax/climax.pdf
I've never found the need to do so.
compression tweeters for <$200 Ang Multi-Way 34 17th February 2012 03:53 PM
FS - Focal TC90K Tweeters MATCHED PAIR Tweeters Mint Condition Unused. Julss Swap Meet 1 20th May 2010 03:45 PM
Celestion Ditton 200 tweeters plemieux Multi-Way 0 30th March 2005 12:52 PM
Difference between Hertz HS-200 and HX-200 FaZ72 Multi-Way 2 8th April 2004 01:34 PM
Aura Ca-200 / Pa-200 cdl Solid State 8 7th October 2003 12:13 AM
Page generated in 0.11316 seconds (81.57% PHP - 18.43% MySQL) with 10 queries
