PORTS!!!! rectangle square, how long? angles, corners, stuffing?? everything else - diyAudio
Old 7th August 2003, 02:22 PM   #1
Banned
Send a message via MSN to SkinnyBoy
Default PORTS!!!! rectangle square, how long? angles, corners, stuffing?? everything else
Okay... I have designed a 60litre for for a Peerless 12inch XLS sub (830500) The total internal volume is 100litres, due to the volume taken up by the port....
Below is a picture..
I have a few questions, is it okay to have a 90 degree angle in the port??
BTW. It took me about an hour to work out how to do this... the final total internal volume is 63litres... then you have to account for the speaker.. the box is tuned to about 29 - 31 Hz.... the final thing will be a 52cm X 52cm X 52cm cube with a slot port the full width of the internal dimension, which btw is 47 cm as I designed the box to use 25mm MDF walls... is there any problem with the design? I thought it was pretty good.. got the volume spot on, and I believe I got the tuning right....
THE OTHER QUESTION!!
How do I measure the length of the port? I personally worked it out by the volume... I knew it had a constant cross section of 47cm X 5cm so I worked out the same volume for straight as bent.. ALSO!! is the gap between the internal end of the port and the speaker baffel big enough? is it a bad idea to have the port sortof facing the rear of the woofer???
THANX!
Old 7th August 2003, 02:23 PM   #2
Banned
Also, I have another question... which port configuration would be better?? this one...
File Type: png peerless box.png (300 Bytes, 166 views)
Old 7th August 2003, 02:26 PM   #3
Banned
Or this one..???
THANX,... feel free to use my design.. lol
DOn't worry... they are BMP's but they are small..
File Type: png peerless box2.png (303 Bytes, 139 views)
Old 7th August 2003, 02:28 PM   #4
Banned
What the front would probably look like..
hehe
WINISD calculated the air velocity through the port to be 13m/s tops at 400watts.. hehe and thats at 30Hz btw.. any comments? should I begin construction? lol
Old 7th August 2003, 02:54 PM   #5
Banned
Umm... no one? lol yeah yeah.. lol I should wait.. lol just someone post to say they have read this.. lol
Old 7th August 2003, 03:42 PM   #6
Banned
Sometimes its fun to talk to yourself.. but not always... I'm going to bed.. SEEYA!! lol
Old 7th August 2003, 03:57 PM   #7
mikee12345's Avatar
personaly i hesitate using a driver that wants such a tiny box with mid tuning and a LONG port.It wastes the 18hz Fs and low efficiency which accompanies the low resonance.
adrian mack <www.geocities.com/adrian_mack >
mentioned this to me,about his PR'd XLS12,how its nearly impossible to build it with a port to optimum specs.
i attempted a ported design,but i always ended up compromising it.
if your using winisd,you could save the project,and add as attachment so i can look over it to ensure im using same inputs.
thats fine
yes
i expect Group delay to be abit high...
personaly id go for the lower quality shiva in a more comfortable sized box tuned to 22hz without 4metre long ports
Old 7th August 2003, 03:59 PM   #8
mikee12345's Avatar
also i think for shelf ports you minus 0.5x port height from the total length because it has different loading to usual.
if im wrong,my jbl2226h is still tuned exactly right with a shelf port anyway:P
www.jlaudio.com ;tutorials;
Old 7th August 2003, 04:02 PM   #9
Banned
Hmmm.... lol
File Type: zip 830500 peerless subwoofer box.zip (867 Bytes, 56 views)
Old 7th August 2003, 05:18 PM   #10
mikee12345's Avatar
i made a spreedsheet that worked out all my volumes for me,saved alot of time.
also,your group delay is alittle high. 27ms.
i would think about using a smaller sized port for only 75cm length approximately.<trade off port speed,but makes it more managable>
it will never be the best, why not save for a PR and tune 19hz?
i had to wait ages to get my jbl2226..
or u cud just get a shiva in 120Litres...
rectangle shaped tweeters skooter Car Audio 2 15th December 2007 04:47 AM
Round vs. rectangle ports... RockysDad Full Range 3 24th November 2005 06:27 PM
curved ports vs. multiple ports Craig Multi-Way 1 22nd September 2002 08:30 AM
Copyright 1999-2017 diyAudio
