Old 13th April 2011, 04:15 AM   #1
noahtheviking's Avatar
Default Driver Attenuation Circuit what watt resistor to use?
I have a 100w pch amp running a 3way speaker setup per channel running 2nd order crossovers I need to take the midrange down 3db I am making a fixed driver attenuation circuit I already have the ohms etc. but I need to know what watt resistors to use I am going to try 10w resistors but wasnt sure if that was enough. I know the amp is 100w pch but the woofer takes up most of the power so that being said would two 10watt resistors be enough for a 50w rms midrange. this is a fixed l-pad driver attenuation circuit. Thanks
Old 13th April 2011, 05:20 AM   #2
ianpengelly's Avatar
10W will be more than adequate, as you are only disappating some of the energy that would have reached the mid-range driver, not all 100W from the amp at max power :-)
Old 13th April 2011, 05:33 AM   #3
thanks for the reply.
cheers
Aleph P Attenuation Circuit amo Pass Labs 13 6th October 2011 07:20 PM
Series Resistor for attenuation in Passive Crossover Eddie Wolve Multi-Way 3 13th November 2010 10:22 AM
Attenuation circuit findings Fe208e sigma adamt Full Range 0 22nd June 2010 02:20 AM
Tantalum Resistor Watt? batsong Tubes / Valves 1 3rd May 2010 06:12 PM
How to put fixed attenuation between preamp and amp. Lpad or just resistor in series? PUCK Parts 1 19th November 2003 03:59 PM
Page generated in 0.06817 seconds (67.86% PHP - 32.14% MySQL) with 10 queries
