Multiple Small Ports With Iso-Barik
Old 12th April 2011, 06:36 AM   #1
Einric is offline Einric  United States
Einric's Avatar
Default Multiple Small Ports With Iso-Barik
I am designing a pair of SMALL monitors (.23 CuFt). I am looking at an Iso-Barik configuration with FIVE .545" ports. Three ports will fire front and Two will fire either rear or upward. What do you guys think?
Here is my theoretical curve.
I chose .545" because it is the ID measurement of a 1/2" Type L Copper Pipe. I can easily Flange it on both ends to reduce chuffing if needed.
Old 12th April 2011, 06:47 AM   #2
Einric's Avatar
A decent EQ can tune the 110hz Hump out and they should be theoretically phenomenal.
Old 13th April 2011, 01:14 AM   #3
PeteMcK is offline PeteMcK
why 5 ports? they will act the same as one larger dia port... (although with more turbulence)
however, this does beg the question, will a box with one rear firing port + one front firing port act the same as a push-push arrangement, for the freq range that the port is putting out?
Re: the hump, it's a bit hard to read your graph, but I'd tune the box a bit higher and you should be able to get a reasonably flat response (at the expense of some low end)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 13th April 2011, 01:38 AM   #4
Einric's Avatar
I have an existing enclosure that has a maximum internal distance of only 7". A 2 inch port would have to be much longer than the space I have to fit the length in. Five .545" ports only need to be 4.96" long each. I am thinking of having three fire front and two will fire down. The Iso-Barik woofer firing to the rear will cause me enough placement issues so I don't want to have any rear ports.
So, the reason I chose 5 ports was to keep them small. I will flare both ends of the ports to reduce "Chuffing".
Multiple Small Ports With Iso-BarikHide this!Advertise here!
Iso-barik? thatotherguy Subwoofers 5 17th July 2008 03:00 AM
Compound , Iso-Barik Lindell Subwoofers 20 9th October 2007 02:35 AM
iso-barik sub odysseybmx414 Subwoofers 3 13th March 2006 07:01 PM
iso-barik subwoofer busterno1 Subwoofers 0 9th September 2003 07:41 AM
curved ports vs. multiple ports Craig Multi-Way 1 22nd September 2002 07:30 AM
