I am sort of interested in the loudspeaker designs that combine a tweeter in a round waveguide with a woofer of the same diameter. These are probably a naive questions. That never stopped me before. :-)
Are the Dayton waveguides usable in home systems? They come in 8",10", 12", and have threaded adapters for compression horn drivers. The compression drivers sold by Parts Express all have very high sensitivity, as much as 110dB. Bass drivers for the home generally have sensitivities in the mid 80's. Is it reasonable to pad a tweeter down that much? Are there less sensitive tweeter drivers that have threaded connections? Are there other inexpensive waveguides available that might be more suitable for home?\
Davy Jones Last edited by Dave Jones; 11th April 2011 at 09:15 PM. |
#2 |
I don't have any experience with the Dayton waveguides but have had good experience using the MCM waveguide that Zaph discussed here: Zaph|Audio. He also tried using two of the Dayton waveguides you mention without as much success to "horn load" dome tweeters.
You may want to look at the EconoWave threads over at PE's Tech Talk forum. Here's a summary link to those: Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com - View Single Post - Flex Your PCD Mettle: These threads are amazingly complete; listing the HF drivers, waveguides. LF drivers, crossover designs, performance, and costs. The designs range from simple low cost ones (hence the "EconoWave" name) to much pricer ones. You should try to match a more sensitive pro LF driver with a waveguide but even then its normal to have to pad the waveguide down. |
#3 |
D220Ti + Dayton 10" is a combination very hard to beat!
![]() ![]() Only DE250+Adapter+JBL Square PT waveguide ("econo waveguide") was able to beat it... very slightly. ![]() ![]() 95+db Woofer is easy to find if you use Pro drivers. Check out my "S15" Econowave build. The JBL is only $12 or so.
http://gainphile.blogspot.com Last edited by gainphile; 12th April 2011 at 01:56 AM. |
#4 |
I used the Dayton 12" WG for a couple years. I had the Selenium, JBL, and B&C drivers. I liked it best with the JBL LE-85 driver. I've also built 4 sets of EconoWaves over on AudioKarma. I think the Dayton round 12" is as good as the JBL, Pyle, or QSC wave guides.
#5 |
I use the two smallest Dayton waveguides (not the larger round ones) and love them for home use. In fact, i think they are too small for all but the smallest pro applications. I've use inexpensive Eminence, Pyle and piezo's with them all to good effect. Depending on the speaker design you go with any of the round waveguides will probably sound great in a home setup. The best size used depends on the approximate crossover point. |
#6 |
Good to hear you like the 12" Dayton WG. I've got a pair and I'm waiting for my Seleniums to arive. I've tried to obtain a pair of those JBL's or Pyles, but that's difficult here in Europe.
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
#7 |
Won't argue that measurement but the CSD (not the one you posted, Augerpro's showed better details) for the D220 is horrible and all my listening tests on using the D220 with the Dayton or Pyle horns just made me cringe. Worst CD I own (I own 5 brands).
There is more to how a CD sounds then the polar response. Its a good start but there is much more involved. I do wish the Dayton round waveguides came has a bolt on option. I believe the screw on types create more diffraction. |
#8 |
The throat (entrance) of these Dayton's WG is indeed problematic and needs some fix.
It's not standard 1" (25 or 25.4mm), 29mm instead. So there's a 2mm step at the conjunction, and then a straight part of the adaptor. Both are not good. I used them with Eminence APT tweeters, luckily the adaptor is plastic and relatively easy to mod. This has been brought up several times. |
#9 |
Hi guys,
Where can the Dayton waveguides be sourced in Europe? Any idea? Thanks! |
#10 |
I'm with Godzilla (if I've interpreted the images properly).
They look like 6" X 6" elliptical Dayton waveguides. I've tried them with success with a BMS 4550 screw-on (only good down to 2.2kHz though). I tried the round 12" with DE250 and adaptor, and with the BMS, and neither of them worked for me, even with open-cell foam. Someone on the forum mentioned using the Dayton 12" only up to 3.5kHz or so. David |
| Compression drivers/waveguides for home HiFi | AllenB | Multi-Way | 29 | 5th May 2010 10:25 PM |
| Dayton Round Waveguides | boudy | Swap Meet | 0 | 21st February 2010 04:37 PM |
| Free 10" Dayton waveguides (UK only) | meshplate | Swap Meet | 1 | 7th June 2009 07:53 AM |
| dayton reference MTM home theater | subynube | Multi-Way | 8 | 7th March 2007 06:01 PM |
| Dayton 5.1 Home Theatre System | Negative Design | Multi-Way | 19 | 28th December 2003 03:29 PM |
| Page generated in 0.12150 seconds (78.96% PHP - 21.04% MySQL) with 11 queries |
