Hi again I'm working on a X12 Speakerplans.com and i'm doubting of some things, first of all, wich type of filter should i use if i want to make a pasive filter? Wich order? wich type?(with wich type i mean, bessel, butterworth,etc.... (my knowledge about electronics, isnt really good)) ![]() And the other question is, at what frequency should the filter separate the 2 woofers freq from the horn-driver??? thx for all |
#2 |
1) You can ask the designer
2) You can use an electronic crossover ,since it's a PA design it may be appropriate . 3) You can use the magic formulas that give you the values ,which may be adjusted later when listening and not finding them good enough. I think that your question is a little naive In this X12 project ,the woofers would be paralleled ,right ? So you'll have a low impedance path for the low-mids and a higher impedance path for the trebles . At what volume will you be listening to them ,when finished ? You can even 'feed' the tw with only a capacitor ( 1st order) at low volumes. Not very safe for the tw if you turn up a little bit . Also ,most important , the passband behavior of any speaker adds its own response to the final curve . |
#3 | |
if not at least several octaves on either side of the putative "crossover frequency" , thereby somewhat complicating things
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#4 | |
1) designer isn't avaible at his email 2) if i use a electronic XOVER (DSP you mean right??) i will need to put two connectors to the X12 right? so i can separate the signal into MF and HF right? Or can i separate it with just one connector?? any advices please? 3)About the magic formulas, i'm starting to look/learn about it. Any good site to look? or cookbook? they are intended to be for high volume application, as loud as possible hehe. My final goal is: I'm building 2 bassreflex box with Fane Colossus 18 XB driver each. (40-200HZ aprox.) And i'm building two X12. Thats why i'm thinking of a passive filter inside the X12 to sseparate MF and HF. And I'm going to buy the correct amplifiers for them and a digital XOVER/COMP/LIM/EQ (DSP) for the all the PA Any suggestions?? Or wich should be the better configuration???What i'm doing wrong? What can i improve? pd: don't be cruel, i'm newbie, and i'm starting to learn everything thx for your help Really appreciate you can take me to the good/best goal |
#5 |
I'm a 1/2 newbie too ( from about 20 years
Making a good crossover for the X12 might be quite a challenge ....also it depends whether you want to obtain a really flat response (hi-fi specs ) or you can live with the dips and peaks of a horn + driver combo . Good thing is to have a mini-lab , with a pc and a microphone and software like ARTA ,so you'll have a solid basis to start with. |
#6 |
I'm thinking this forum needs a subtitle, as "fullrange" isn't always taken by newbs to mean "fullrange drivers". Can't blame them, as "fullrange speaker systems" is a common and perfectly acceptable nomenclature.
#7 |
Speakerholic
Moved to Multi Way
| HELP for change parallel design to Series design Xover | FREEMANMKII | Multi-Way | 11 | 21st September 2010 07:31 AM |
| NAD 208 THX Serice Manual/Schematics needed | Colin151 | Solid State | 1 | 6th December 2007 01:00 PM |
| Xover guru needed - help! | dpaws | Multi-Way | 2 | 30th January 2007 01:05 AM |
| Xover help needed | stueyh | Multi-Way | 0 | 6th September 2005 08:36 AM |
| THX certification, or integrated near THX Quality, | extremy | Tubes / Valves | 4 | 6th October 2004 05:04 PM |
| Page generated in 0.12626 seconds (78.92% PHP - 21.08% MySQL) with 10 queries |
