Dynavox LW5004PMR 5-1/4" Woofer
Dynavox LW6004PMR 6-1/2" Woofer Last edited by Bill poster; 10th April 2011 at 10:16 AM. |
#2 | |
It's all about T/S... b |
#3 |
Cheers fella, makes more sense now; I like the smaller ones but can't see any stockist in europe unfortunately
#4 |
If you have any other questions on usage, Ben "Wolf" Shaffer has worked with the 5-1/4" Dynavox woofer and can probably point you to the right tweeter, crossover tweaks, etc.
If it works, but you don't know why it works, then you haven't done any engineering. Taterworks Audio (nothing for sale) |
#5 |
Two Dynavox LW6004PMR 6-1/2" Woofers with Vifa DX25TG tweeter with crossover.
Some design help please http://www.lyeco.com.tw/co.htm Last edited by Inductor; 10th April 2011 at 11:12 PM. |
#6 |
Thanks taterworks/inductor, its a possible project ie a friends wants me to make him a set of monitors for his home studio.
I thought of using the excellent jordan JXR6 crossed with either of the dynavox units or possibly an aluminium woofer like the FW168 (but power handling is just 50 w). The jordans i can get a bit cheaper than normal and also the cabs in corian through a fabricator mate, so i reckon all in around 350 euros for a cracking pair of monitors. One Q. because the dynavox material is different to the jordans, will using a 1st order(at 375 hz) cause a problem? Last edited by Bill poster; 11th April 2011 at 03:13 PM. |
#7 |
There was a big problem with that with the voxs. I would have to look again. Can you be more explicit? The 375 Hz would be a (new) possibility...
#8 |
#9 |
Probably the low xover frequency makes it possible to use a 1.order, but the attenuation is not very nice as seen from it's (driver) output frequency (from my memory). I think you mention 1.order and it requires very good (behaved) drivers.
#10 |
Load a small box (.35) in Iso-Barik and tune the ports (I chose three) for GREAT theoretical response.
| Dynavox LW6004PMR first impressions. | K-amps | Multi-Way | 6 | 7th September 2007 05:53 AM |
| FS or trade 1 pair Dynavox 6.5" woofers, 1 pair of Tweets.. | JCoffey | Swap Meet | 4 | 20th September 2006 04:56 PM |
| Dynavox high Q woofers..... | studiotech | Multi-Way | 0 | 24th October 2004 02:52 AM |
| Anybody has this Dynavox driver handy? | Thunau | Multi-Way | 3 | 29th May 2004 09:10 AM |
| Dynavox tweeter | RussianBlue | Multi-Way | 0 | 12th February 2004 06:58 PM |
| Page generated in 0.10666 seconds (77.53% PHP - 22.47% MySQL) with 11 queries |
