Tweeter Resonance Frecuency
Old 6th August 2003, 06:26 PM   #1
Higo is offline Higo  Argentina
Question Tweeter Resonance Frecuency
I have a pair of Audax AW010E1. They have a resonance frecuency in 3K. I was reading in Elliot´s page that He "suggest an absolute minimum of about 2.5 octaves between the driver
resonance and crossover frequency". What happens if I use a XO frecuency of 4K and I use a correction circuit (I mean a RLC circuit in parallel to TW)? Is it right? Any comments would be appreciated.
Greetings
Marcelo.
There is no emotion; there is peace.There is no ignorance; there is knowledge.There is no passion; there is serenity.There is no death; there is the Force.
Old 6th August 2003, 06:39 PM   #2
mhelin is offline mhelin
It's OK, but there might be problems with the phase (each filter somehow changes the phase, in speaker design you should consider both, not just the frequency).
Old 6th August 2003, 10:41 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
The standard rule of thumb is allow two octaves OR use a resonant trap filter.
If you design your peak filter carefully, you should have no problem with the tweeter crossover, assuming the tweeter can handle being crossed at that frequency.
Best would be to use at least a 2nd order crossover along with the peak filter. Steeper slopes are important when crossing low, unless you will only use them for background music.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. —Aldous Huxley
Tweeter Resonance FrecuencyHide this!Advertise here!
frecuency level display glazarou Equipment & Tools 2 10th June 2006 04:41 PM
frecuency level display glazarou Equipment & Tools 3 2nd June 2006 01:33 AM
series crossover with resonance trap for tweeter? madinoz Multi-Way 0 8th June 2005 02:03 AM
High frecuency oscillation when moving volume pot pingfloid Tubes / Valves 43 20th April 2004 11:16 PM
tweeter double resonance? leftnote Multi-Way 6 9th February 2004 12:36 AM
