Old 8th April 2011, 07:01 AM   #1
tocs100 is offline tocs100  United States
Default Passive hipass question
Been reading about Zobel and lcr networks, and have all my parameters collected, but I'm a bit confused on computing values of caps and such.
I've got a 2x6" box, 14 liters, 6" speaker-specs here:
Fs 118
Qes .60
Qms 5.63
Re 7.2
Now I know I don't double the Fs, but what about the other stuff? Since the crossover will see 14.4 ohms from the 2 6" in series, is that what I put in an online lcr calculator? My hipass point btw is about 650Hz.
I also want to run an 8ohm (Re 5.3, Le 0.52) 15"-cab in parallel before the 2x6," but I don't want to lopass the 15", as it'll run fullrange on one side of the stage.
So the system order is
8ohm sub, parallel out to
hipass cap, zobel cap & resistor, LCR network, 2x6" speakers in series for 14.4ohm load.
So when entering impedance in online calculators, is the crossover just concerned with (1)the speaker immediately after it?, (2)all speakers after it?, (3)or all speakers in the chain incl. the sub before it (which is 4ohms total)?
Depending on that for instance, my inductor could vary from 6m.h, 12m.h. or 20m.h.!!!
A BIG sketch of the circuit would be welcomed too.
Hi:) and a passive cross-over question BMWTurbo Car Audio 7 26th November 2011 12:00 PM
Hipass filter to control master bias? - Why attempt to reproduce DC in a tube amp? speakerfritz Tubes / Valves 13 12th December 2010 02:23 PM
Passive xover question ttako Multi-Way 1 23rd February 2009 08:46 PM
passive radiator question krikus050 Multi-Way 7 5th October 2008 06:53 PM
hipass/lowpass filters maylar Tubes / Valves 0 5th January 2004 08:50 PM
Page generated in 0.06254 seconds (66.85% PHP - 33.15% MySQL) with 10 queries
