Hi guys, I just want to check if the speakers I have are correctly phased (just for clarification: with that I mean if the + and - are correct). Reason why I want to check was because my new speakers don't sound that great even when red is connected to red and black is connected to black. When I checked on my AV receiver, my av receiver said they front speakers were out of phase. When I reversed the wires that message disappeared. However, according to the manual of my AV receiver, it is actually possible to get "out of phase" warning even when they are correctly connected, so now I'm trying to figure out how I can check if it is the speaker design or if they are truly out of phase (meaning the + and - were reversed internally)
Any suggestions? |
#2 |
Use a 1.5 volt battery and see if the cone goes in or out.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
I did, and I see the bass cone come out, so I guess the phase is correct (Mind you, I didn't see the tweeter and mid range unit move, but I read somewhere that tweeters and their crossovers don't react to DC power, is that right?). Maybe it is because they are 4Ohm speakers and that might throw off the calibration on the AV receiver. SO for now I assume they just need breaking in.
#4 |
Do a simulation of your filter and see what the phase does.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#5 |
eh? how do I simulate my filter and with what?
#6 |
Search for freeware filter simulation software.
Or freeware simulation programme like symetrix or other spice programs. here you can find a lot of freeware tools for audio. Steve Ekblad's Free Audio Software and On-Line Enclosure Design
#7 |
Feed mono noise, such as FM intersation hiss to both speakers. Place them face to face and reverse the connections on one speaker (try both ways). You will hear very strong output with both speakers in phase, and nearly full cancelation when they are out of phase.
Must be mono noise. Full cancelation across the band means the speakers are well matched. David S. |
#8 | |
| Acoustic phase, electric phase,....phase | ermes | Multi-Way | 6 | 27th November 2010 06:17 PM |
| Checking tweeter phase | eRiCdWoNg | Multi-Way | 3 | 1st October 2005 11:11 PM |
| Checking in... | ghudnub | Introductions | 1 | 19th September 2005 03:58 PM |
| Checking used capacitor | chris ma | Everything Else | 7 | 24th June 2003 12:59 AM |
| Newbie checking in | toenail | Introductions | 6 | 8th March 2003 01:15 PM |
| Page generated in 0.08766 seconds (81.20% PHP - 18.80% MySQL) with 10 queries |
