Response all the out to around 10 KHz before rolling off, 4 ohms, around 95 db @ 2.83/v/1m, Qts around 0.3 or so, and at least a few mm of xmax. High pass will be LR2 via 0.5 Qtc to a large (15"+) vented or TL woofer, low pass will be LR2 around 2.5 KHz to a sensitive dome with enough guts to handle the power, haven't quite decided which one yet.
..Any ideas? |
#2 |
If only Pyle wasn't always such a shot in the dark..
Pyle Pro PM6DC 6.5" 400 Watt Midrange Pyle Pro PDN65 6.5" High Power High Performance Midbass Pyle Pro PM65CP 6.5" Midrange Pyle Pro PMN65FP 6.5" Midrange Someday, they'll all have sketchy T-S params underneath cutout info in PDF's on their crappy website. Until then, no idea. |
#3 |
Acoustic Elegance TD6 is worth a look.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#4 |
Paul,
Since you are on line can you tell me the Sonogram software you use to measure the drivers/speakers directivity. Thanks. BHTW, I use PHL drivers they are quite good with high efficiency around 95dB, they have a number of midrange 6-7", I am not confident it will go all the way to 10kHz. There are number of models available at E-speakers, Welcome to E-Speakers.com - Very High End Loudspeaker Components PHL 1120 may fit your bill. |
#5 |
TT, you have mail
#6 |
http://www.ciare.com/pdf/catalogo/CM165NDA.PDF
http://www.supravox.fr/anglais/haut_parleurs/tg1.htm Unfortunately no cheaper high sensitivity domes with 4 Ohm. Last edited by el`Ol; 4th April 2011 at 07:57 AM. |
#7 |
The High Efficiency Speaker Asylum posted a few T/S specs for the Pyle Pro PDN8 PDN65.
If anyone on diyAudio has measurements please post. The speaker pictures look interesting for their $37 - $45 price point. ================ A car audio website posted this T/S data for the Pyle PDN8 copied from the datasheet enclosed in the shipping box. There were a few positive comments on the PDN8 from actual owners. I need an Fs ~40Hz, so the PDN8 is not an option. Pyle Pro PDN8 8" Mid-bass ( ~$45) 8'' Kevlar Reinforced Paper Cone Cloth Multi-Roll Surround 2'' Flat Wound CCAW High Temp Voice Coil Die-Cast Aluminum Frame Aluminium Phase Plug High Density Neodymium Magnet 500 Watts Rms/1000 Watts Peak Power 4 Ohm Impedance Sensitivity: 94 db (1W-1M) Frequency Response: 90Hz-10KHz F0 (hz) - 100 QES - 0.58 QMS - 8.2 QTS - 0.55 VAS (cuFt) - 9 SPL (db) - 94 Pyle Pro PDN65 6.5" paper cone/ 1.5" voice coil Die cast frame/ aluminum phase plug Neodymium magnet 4 ohm 94db/watt =============== Bruce Edgar I recently purchased a PDN65 from parts express to see how it would perform as a midrange horn driver. The spec sheet gives the following TS parameters: Fs=105Hz, Qms=8, Qes=0.55, Qts=0.53, VAS=6.5cuft, Sens=93dB, and maxpwr=800w. |
#8 |
that looks real good
small driver with 2" voice coil having a center plug, isn't that a first time we see that monster center plug for such small driver |
#9 |
Not quite what was asked for.. but how about a pair of B&C 6MD38's parallel in a compound load?
perspective is everything |
#10 |
Do you mean "isobaric" ?
What's the benefit for midrange in such configuration? |
| "Best" extended midrange driver below $200 ? | youyoung21147 | Full Range | 48 | 6th May 2011 03:22 PM |
| "Midrange enclosure" articles | claudio | Multi-Way | 6 | 8th August 2010 01:21 PM |
| "Vifa PL11WH09-08 Premium Line Paper cone midrange" | GOWA | Multi-Way | 0 | 17th November 2007 01:22 PM |
| Closed back midrange drivers 4" maybe 3" - recommendations please | RobWells | Multi-Way | 2 | 22nd February 2007 04:59 PM |
| Warm 4" - 5" midrange | Leffemannen | Multi-Way | 6 | 29th March 2006 04:50 PM |
| Page generated in 0.09871 seconds (83.41% PHP - 16.59% MySQL) with 11 queries |
