I have a couple of speaker I want to convert in to an active soundbar for the fun of it. The original cabinets are vented, but I want to shrink the size and make the hole thing closed.
How do I calculate the conversion from vented to closed size, does anyone know? |
#2 |
Speakerholic
Are you just winging it? If you don't have the T/S parameters to design the actual Q=.707 then guess at around 2/3 the size of the vented. Most drivers offer parameters that dictate the type of enclosure they should go in. If they were in vented, they might not give you want you are looking for in sealed.
#3 |
Guess I am, sort of wingin' it. I don't have any data for the drivers yet.
#4 |
Speakerholic
Maybe post your ideas and some of the smarter types might have a direction for you to head. Good luck with it.
#5 | |
In my head it's quite easy. Take the drivers out of the original cabinets and place them in new, soundbar-type cabinet, with the midwoofers facing the center of the bar, where I picture a chipamp of sorts, and with the tweeters flanking them. I upgrade the xovers with some nice components, put everything in its own internal compartment and hook it up directly to the chipamp, wich will have one set of inputs, hooking it up to the flatscreen. Dunno if I can control the volume like this from the tv, if not, perhaps a simple cheap remote would do fine. As I said, just for fun, but would be nice if it actually turned out useful I'll have to snoop around for some driver specs. |
#6 |
Why do you want to make it closed out of interest? If the drivers are designed for a vented box, they'll fare better in a vented if you want to make it smaller.
Also, it's better for directivity and lobing to put the tweeter in the centre and a pair of midwoofers either side. IMO, going for a mono approach might be preferable as you're not going to get a whole lot of seperation in a small cabinet under the TV. |
#7 | |
I figured that a closed box could be made smaller than a vented one. No toher reason. I know the stereoperspective aren't going to be great, but it will be present, however inferior to other designs. Allthough I could make it mono, just as a project, but I really don't see the benefits in comparison. I am leaning towards just putting everyting in a box similar to the volume of the other two combined and see what happens with a generic xover of some kind. |
| My DIY Active Soundbar! | Ridin '24'z | Multi-Way | 42 | 15th December 2011 10:13 AM |
| LCR full Range Soundbar | kampo | Full Range | 10 | 17th March 2011 11:28 PM |
| why no DIY SoundBar designs | bbaker6212 | Multi-Way | 16 | 1st August 2008 05:19 AM |
| DIY active x-over for 2.1 application | peter_m | Multi-Way | 17 | 16th December 2007 04:22 PM |
| DIY active cable | Koy | Solid State | 37 | 17th April 2003 12:09 AM |
| Page generated in 0.08582 seconds (77.13% PHP - 22.87% MySQL) with 10 queries |
