I'm looking for a really good 10" for using upp to 700 hz in a centerspeaker with a Tad horn above. I want Tads tl 1102 but they arent easy to find. What can i use instead ?
Mats
James B Lansing= Nr 1 |
#2 |
A B&C 10" woofer and a DE250 make for a very good combination.
#3 |
Mats,
In the USA both JBL and Acoustic Elegance Lambda are popular midranges. I own many Lambda speakers because of their natural tone created from good motor designs and well damped, midweight paper cones. Do a search on the TD10M for more opinions. The JBL 2012 H/J consistently gets high recommendations from the Altec forum. It has a modest increase in SPL with higher frequencies. JBL 2012 Fs= 61Hz, Qts= 0.22, SPL= 100db/watt Acoustic Elegance LAMBDA speakers: True midrange with accordian surround TD10M - 8ohm Fs: 40.5Hz Qms: 2.7 Vas: 59L Cms: .35mm/N Mms: 44g Rms: 4kg/s Xmax: 6mm Sd: 345 Qes: .26 Re: 6.6 Le: .2mH Z: 8ohm Bl: 17Tm Pe: 500W Qts: .23 1W SPL: 93.9dB Acoustic Elegance LAMBDA speakers: Midbass with foam roll surround TD10S- 8ohm Fs: 32.7 Hz Qms 3.04 Qes 0.39 Qts 0.34 Vas 68 Liters Cms 0.4 mm/N Mms 59.4 grams Sd 345 cm2 Rms 4.0 Kg/S Bl 13.1 T/m Re 5.5 ohms Z 8 ohms Le 0.3 mH Pe (max) 500 Watts Pe (transient) 1000 Watts 1WSpl 90 dB Linear Xmax 14 mm (peak) Mech Xsus 18 mm (peak) |
#4 |
I have TADs 1102 in my main speakers and if i could get a another pair i would use them. There must be something similar to these.
mats
| Need a good recommendation on a "great" sounding 7.2 surround amp | Thaedge | Solid State | 0 | 10th March 2011 03:49 PM |
| Good 10 " for TL | Madmike2 | Full Range | 3 | 17th May 2005 09:50 PM |
| A good sounding 6.5" midbass, efficient (>=90dB) and under 100$, does this exist? | Bricolo | Multi-Way | 11 | 24th November 2003 11:03 AM |
| What are "good" sounding resistors for my aleph p | Shaun Perez | Pass Labs | 6 | 29th July 2003 01:46 PM |
| good 10" woofer | jimsdaho | Multi-Way | 9 | 15th June 2003 11:47 PM |
| Page generated in 0.08227 seconds (73.60% PHP - 26.40% MySQL) with 10 queries |
