You have a crossover box with 1 set of inputs and 3 sets of outputs to drivers
There is the same LCR network in parallel to all three drivers at the outputs (three networks) would this be equivalent to one of the same LCR network across the input set? (one network) You can assume no other circuity Trying to understand AC flow at the crossover better thank you
#2 |
Hard to guess what you're talking about without a diagram, but I would assume no until I see it.
#3 |
ImageShack® - Online Photo and Video Hosting
![]() Don't know why the pic won't show Are those two equivalent? same LCR network obviously beautiful circuit diagram i know i'm for hire |
#4 |
Ok, no they won't be the same.
There may be a bigger issue to talk about, if you're interested in expanding it. If there were actual crossovers in the diagrams they would be placed between where you have the single LCR and where the separate LCRs are. These two types of circuit are used for different things. The single LCR used directly after the amp would be used to flatten the impedance to make the speaker an easier load for your amp. This would have no real impact on the frequency response of the speaker. The separate types are used for flattening/altering the impedance of individual drivers so the crossovers, for example, can perform more predictably. Series components need to be placed before them to make them effective. |
#5 |
Great! makes sense, thank you
| simple se inrush limiter placement | pforeman | Tubes / Valves | 7 | 5th September 2011 01:19 AM |
| capacitor placement question | reddish75 | Solid State | 2 | 11th April 2009 02:21 PM |
| have a placement question | Jonny Hotnuts | Car Audio | 5 | 20th December 2007 11:57 PM |
| Capacitor placement question. | Wing_of_Souls | Car Audio | 6 | 5th August 2004 12:46 AM |
| Question on port placement??? | Javaman | Multi-Way | 0 | 16th October 2003 01:34 PM |
| Page generated in 0.08128 seconds (72.30% PHP - 27.70% MySQL) with 10 queries |
