Old 27th March 2011, 07:23 AM   #1
prickears's Avatar
Default Program for designing box by desired Q?
Does anyone know of a box program that can recommend a box size and port size by entering desired Q?
many thanks.
Mick.
Making stuff 'idiot proof', Just breeds more effective idiots.
Old 27th March 2011, 04:26 PM   #2
By desired Q I assume you mean the Qts of the driver.
Just about all of them will do that, as I recall, but you also have to enter such things as the free air resonance, (Fs), and the volume of acoustic something or other, (Vas).
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 27th March 2011, 04:48 PM   #3
infinia is offline infinia  United States
infinia's Avatar
Q implies a second order system. meaning closed box ie no reflex ports and such.
Qts and Fs of a driver placed in a sealed or closed box will be raised by the apparent air volume.
WinSD beta works and is easy >google speaker box modeling software
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 27th March 2011, 04:59 PM   #4
winisdpro from linear team.
regards Andrew T.
Old 27th March 2011, 05:02 PM   #5
infinia's Avatar
beta is the version to play with basic box parameters, WinISD pro is very difficult for newbies.
Old 27th March 2011, 06:40 PM   #6
AuroraB is offline AuroraB  Norway
AuroraB's Avatar
Q is the general term for the whole system, which mostly describes the system behaviour around the lower f3 - of the total system..........which can be anythinng from fisrt order and upwards....
BRs are usually 4. order....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 27th March 2011, 08:56 PM   #7
Q might imply a closed box system to an experienced builder familiar with Thiele and Small. However, I think there is a chance that prickears is just getting started with this, has a woofer with a listing for "Q", (Qts), and would like a box volume and port size for it. Most programs will tell him that, if you list Fs and Vas as well.
Perhaps the best thing would be for prickears to list the specifications for his woofer and somebody here can tell him box volume, port size and length. I would offer to do so, but until my new netbook comes in from Amazon I am using an old iMac eggshell with antiquated OS and software, and I doubt I'll be able to download any box programs on it.
-Anonymous
Old 27th March 2011, 10:15 PM   #8
prickears's Avatar
Thanx guys,
Actually, I generally use Unibox, it seems most basic programs give you a max flat alignment for a ported box, (butterworth QB3?) I think all BR's are 4th order, but the shape of the slope can be fiddled, and that is what I am interested in.
I am dealing with a room that doesn't mind boosting the bass quite a bit, and in fact 'max flat', in this case is just too boomy, so I figured I might try for an earlier but slower shape to tighten up the bass and drag a bit of boomy-ness out of it. So yeah, really just an attempt to get the room and system to merge together a little better, but I don't want to thin out the bass too much, if that makes sense.
Mick.
Old 28th March 2011, 12:26 AM   #9
infinia's Avatar
Hi Prickears
I too use Unibox but I find WinISD beta easier to experiment with the basics to optimize things quicker ie fiddle, then take the parameters found back to Unibox to finalize and cross check the design.
Old 28th March 2011, 12:41 AM   #10
infinia's Avatar
Hi AuroraB
yes you can measure Q for any resonance f/BW, but there are no equations other than a 2nd order system to design with.
Designing Box lamsv Subwoofers 4 5th September 2010 04:37 PM
Speaker BOX program? jmar Multi-Way 1 22nd December 2007 03:30 PM
Designing a box dan50 Subwoofers 2 18th September 2007 05:58 AM
What program will allow you to input the T/S parameters and make a speaker box design kehi Multi-Way 3 11th December 2003 01:05 PM
Help with designing a box tom1356 Multi-Way 11 17th October 2002 04:45 AM
Page generated in 0.10116 seconds (76.54% PHP - 23.46% MySQL) with 11 queries
