what are the advantages or disadvantages in this case ?
HOW ? WHEN ? |
#2 |
room reflection can make it sound booomy.
Some manufacturers make boxes that have woofer facing the dottom, sometimes it can be helpful, many times can sound horrid. It vastly depends on the room it self to be honest. |
#3 |
Try and remember that a port is a Helmholtz resonator. There should be little or no difference regardless of where you install a port, as long as its flow isn't impeded or changed by nearby boundaries. Also you don't want port placement to allow backwave (midrange frequencies) from the woofer to leak out of the enclosure through the port.
If you have a down firing port, you need to take into consideration the nearest boundary, which is the floor. Floor loading is actually pretty good as long as it is done right. |
#4 |
There is a seamless transition between 'BR', and a mass
loaded quarterwave speaker. In a tall speaker, where e.g. the driver is mounted on the top and the port is at the lower end, you will get noticeably different behaviour than calculated for a 'pure' helmholtz resonator, where it is assumed to have the (inner) port near the driver and the cabinet's air acting like an ideal spring. For common dimensions there is of course some freedom in port placement, as the driver-port distance is usually small compared to a quarter wavelength at the tuning frequency. Having the (inner) port at pressure maxima of standing waves in the cabinet, may lead to upper bass/lower midrange resonances being more audible when radiated through the port, especially as a typical BR is not stuffed heavily ... It is important to know, whether the box will be used as a subwoofer or as a 2-Way e.g. To have a modal analysis of the box resonances and not place the inner port near the pressure maxima of the lowest modes may be advantageous in case of a larger band to be reproduced. This is for the inner port. To have the outer port near the floor e.g. may yield a little boost in the port's radiation and dependent from the port's orientation the mass component may increase, allowing to make the duct a little shorter for the same tuning. Last edited by LineArray; 27th March 2011 at 02:11 AM. |
#5 |
Well, I guess it all depends upon whether he is building a bass reflex or a mass loaded quarter wavelength.
#6 |
is for this project
witch 8948A usher driver .
HOW ? WHEN ? |
#7 |
frugal-phile(tm)
That is going to be an ML-TL
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
fb is at 40hz
inside useful volume is 23 L for now project looks like this
HOW ? WHEN ? |
#9 |
Other opinions, suggestions
HOW ? WHEN ? |
| MTTM advantages/disadvantages? | jjkozlow | Multi-Way | 17 | 16th January 2012 05:30 AM |
| Parallel output tubes/valves in push pull. Advantages/disadvantages? | Matt.B.H. | Tubes / Valves | 42 | 20th May 2010 03:27 AM |
| Chassis metal advantages/disadvantages? | bereanbill | Tubes / Valves | 60 | 9th June 2009 03:29 AM |
| Bottom port for Proac 2.5 clones | DirkD | Multi-Way | 1 | 20th August 2004 10:54 AM |
| Page generated in 0.09639 seconds (77.11% PHP - 22.89% MySQL) with 11 queries |
