Old 27th March 2011, 03:40 AM   #11
infinia is offline infinia  United States
infinia's Avatar
Originally Posted by DionG View Post
sorry im a bit of a novice here
do you recommend any software in particular?
thanks
Dion
this what I use > uni-box UniBox - Unified Box Model for Loudspeaker Design - Kristian Ougaard
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 27th March 2011, 03:41 AM   #12
DionG is offline DionG  Australia
cheers thanks infinia
Old 27th March 2011, 05:36 AM   #13
Francec is offline Francec  Australia
Banned
Dion,
What are planning to do with the driver?
Frank
Old 27th March 2011, 12:40 PM   #14
ohk this is the setup: (all crossovers active, thus tri-amping)
1 Fahrenheit 15" subwoofer (as far as i know its an unknown brand but i got it cheap, $50, and took a gamble. i seams to have paid off, sounds nice etc.)
crossover at 80-100hz
2 bass/midrange drivers. here im thinking the 830883's
active cross about 3kHz i guess
2 tweeters, undecided yet
at the moment all are planned to be powered from LM3886 amp boards due to their quality
Old 27th March 2011, 01:21 PM   #15
I was also considering using the following as it is class D and will run cooler.
although it can reach 100W per channel its 10% THD. however, running it at 70W (0.005% THD) per channel and bridging it into an 8 ohm speakers seams good.
Class D amp
thoughts?
Dion
PS
this is the class A or AB everything was planned to run on so far:
LM3886
Old 27th March 2011, 09:51 PM   #16
Banned
Dion,
I can tell you for certain that you won't use anywhere near 70 Watts for one driver in an active three way system. I have an active three way using an 8", 5 1/4" and 25mm and the transformer I use is rated at 160VA. When it is at about half volume, the guy in the next street can hear it fairly clearly so, unless you have cast iron ears, you won't use power that high.
I am in Port Melbourne, so if you are in Melbourne, you are quite welcome to have an inspection and listen.
Frank
Old 28th March 2011, 01:01 AM   #17
Frank, basically im trying to kill 2 birds with one stone, ie. general usage stuff and occasionally music for parties. the reason i wan to them to take high power is so they can be turned up, without them getting permanent damage.
again the bridged amp into the 8 ohm can only physically put out 135 watt. so say 110 to 125 watt RMS would be the maximum (assuming they can handle the volume).
Im going to guess your going to say that thats to loud but either way, do you think the 830883's will take 130W music style power or if you think theirs definitely a better option?
cheers
Dion
Old 28th March 2011, 01:55 AM   #18
Banned
Dion,
If you are tri-amping, you WON'T need to use that much power to an individual driver. There won't be any losses in a passive cross-over to worry about plus you won't be dividing the power of an amp between three drivers.
I use;
8" Peerless 830869
51/4" Peerless 832873
1" Vifa very old
tri-amped with LM3886 for all and bridged on the woofer.
I repeat the offer; if you are Melbourne, you are welcome to have the cobwebs blown out of your ears with my speakers to hear how loud they can be. If you used mine at a party, no one would hear themselves think, let alone hear what someone else is saying.
Frank
Old 28th March 2011, 02:02 AM   #19
alright haha
are you 8" ones running of single chips each?
but no sorry im in QLD, thanks for the offer though
cheers
Dion
Old 28th March 2011, 02:06 AM   #20
infinia's Avatar
Frank
Hi
that's the typical description of a system under high distortion. I would think the mid amps are clipping 1st, with small mid drivers around 86dB/m sensitivity. I think it's more important to have extra gain pwr overhead so you never reach compression.
Peerless HDS & Exclusive FS thadman Swap Meet 2 22nd September 2009 07:27 PM
FS: Peerless HDS 830883 6.5" woofers paean Swap Meet 3 16th September 2009 06:24 PM
Peerless HDS Exclusive - consistency check Multi-Way 6 17th July 2008 11:44 AM
SS9700+Peerless HDS 205 EXCLUSIVE cypher Multi-Way 4 11th September 2007 03:04 AM
ML-TQWT with Peerless HDS exclusive? tubee Multi-Way 0 18th June 2007 08:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
