Hi there
I already have the Monacor SP12A-302 PA which is used in the "Menhir" loudspeaker (quite well known in Europe?) - see MONACOR INTERNATIONAL:Product detail page= As I am not 100% satisfied with bass performance in the current set-up I was wondering, whether this driver would work in a rear loaded horn to get a flat response down to approx 50Hz? Sort of like a FAST with the Sub from 20-50, the "full range SP12A-302" from 50-1500 or 2000 and then the Tweeter from 1500/2000 - ok more or less a classical 2-Way but with BL-Horn for the lows... Any opinions? Length of such a horn - more like 0.6m (Hornkehle) or more like 1.5m (classic)? Mouth-opening? Many foldings to avoid the medium frequencies from getting through the horn or just as straight as possible? horn contour favorites? Or is this just a bad idea? Length/volume of the horn would be less relevant as the loudspeakers will be integrated into a inwall system with a depth of approx 30cm - given a heigth of 2.4m and a width of up to 1.1m - there should be more than enough space for also more exotic ideas... Or should I simply put this woofer into a closed box... Many thanks for your suggestions / ideas Saludos Drrum |
| BL Horn Project Helix-5000 | widowmaker | Full Range | 11 | 12th November 2008 04:40 PM |
| Fostex FP203 BL-Horn | Roemhild | Full Range | 11 | 20th September 2008 10:09 PM |
| Fostex FE206E BL horn speakers | sarrisk | Full Range | 7 | 31st August 2008 03:04 PM |
| Fostex Fe208Sigma BL-Horn (Replikon) | Roemhild | Full Range | 8 | 15th November 2005 11:01 AM |
| TQWP, Onken, BL Horn | AlexanderS | Multi-Way | 0 | 23rd March 2005 09:15 AM |
| Page generated in 0.05124 seconds (76.79% PHP - 23.21% MySQL) with 11 queries |
