type of port for vented box
Old 21st February 2012, 12:16 PM   #21
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Have a search for the Eminence Designer software. It comes with a bunch of TSPs for Eminence drivers, but works as well with any speaker of which you've got the TSPs.
Good luck!
Old 29th October 2016, 01:26 PM   #22
yoke is offline yoke  Croatia
yoke's Avatar
Hi, I know this is old tread, but, does any one have any opinion about using cardboard tube from printer paper in role
would it be better, worse or it doesn't meter compered to plastic tubes ?
I can't find 5cm commercial plastic bas reflex tube, near me, but have those in my hand
but I can order them so it's not crucial for me to use cardboard tubes but as I have tham, I tought to use them...
But at the and I would like to use the best possible I can, so If the plastic is better than cardboard I will order them
thanks
here is the picture of what I have
Old 29th October 2016, 02:24 PM   #23
Sonce is offline Sonce  Macedonia
It doesn't matter, if the tubes are straight. Some plastic tubes have flared both ends, and they are better.
Old 30th October 2016, 07:03 PM   #24
yoke's Avatar
Thanks Sonce for replay...
I can "flared" cabinet at the port end with router...
Old 30th October 2016, 09:41 PM   #25
GM is offline GM  United States
GM's Avatar
FWIW, in doing velocity stack research for carbs, injectors many decades ago we found that until the flare radius = pipe radius, which doubles the effective pipe area [(Av1*Av2)^0.5], that they were basically just cosmetic, so best to design based on a low vent mach.
10% is listed on Collos's site, but 5% and even as low as 3.5% with some alignments is more realistic with today's [super] high power handling [sub]woofers.
Another option is to cut the pipe at a 45 deg or steeper angle on both ends to create a larger oval termination, though of course a real 'pain' if one doesn't have the tools [or at least the patience] to angle cut the baffle.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 31st October 2016, 02:25 AM   #26
horst303 is offline horst303  Australia
Also if the port becomes too long for the box, you can put two or more ports of a smaller diameter and length to achieve the same result.
Old 9th November 2016, 05:04 PM   #27
chrisb is offline chrisb
If the box has enough net cubic volume, you can use ABS plumping pipe for which 45 and 90dg fittings are available to fold the port - then there was that clever Fostex design (FE167E) in which the port was integrated into the floorstand.
http://fostexinternational.com/docs/...7e_enclrev.pdf
like my mind, this space intentionally blank
type of port for vented boxHide this!Advertise here!
In Bass reflex box (vented)-If I make smaller box than what consequences will I have? eliaselias_0 Multi-Way 6 3rd January 2011 03:49 PM
L-shaped port for vented design runethechamp Multi-Way 3 27th May 2009 05:11 AM
Flex hose as port in vented cabinet ? Jan Dupont Subwoofers 19 27th March 2007 03:53 PM
Can I mod an old labriynth box to be a vented box? MikeHunt79 Subwoofers 7 23rd May 2006 06:44 PM
Vented Enclosures - What type is this? nrgy Multi-Way 8 29th March 2004 08:21 AM
