Old 23rd March 2011, 05:58 PM   #1
Default is my 3 way wired in right
how do I wire this up????
Hello I have a couple of old radioshak speakers that someone built. there is a sub wooffer (Korea ?SHARP? PT#C250L22S3251), mid range 650-11K? stated on back (radio shack pt# 40-1282C), and a tweeter (radio shackpt#40-1278B). The Universal 3-way cross over (radio shack PT 40-1299A) has terminals A-F, with two letters designated (choice of frequency) for each speaker along with a negative for each speaker. I am trying to find out if it is wired in corectly.
All of the negative line up, the positives for the wooffer :B
mid
tweeter :F
my main question is that the positive for the tweeter doesnt go directly to the tweeter, instead it connects to a "fork of two capacitors (??), one
?capacitor? is soldered to the tweeter and one is soldered to the mid range, does this sound right??
Picture:
owners manual:
http://support.radioshack.com/suppor...oc65/65787.pdf
Old 24th March 2011, 09:35 AM   #2
AllenB is offline AllenB  Australia
It sounds reasonable. Can you fix your linked image?
Old 24th March 2011, 02:24 PM   #3
Default here is the image
here is the image
File Type: jpg $(KGrHqMOKpwE1rGE0vihBNe-Frg)v!~~_12.JPG (26.5 KB, 23 views)
Old 26th March 2011, 11:20 AM   #4
Does the speaker sound OK as it is or are you trying to fix a problem with its sound?
Ill be getting wired here now... phluffy Introductions 2 4th May 2009 03:42 PM
OpAmps wired in parallel Alfetta87 Digital Source 7 20th August 2006 07:57 PM
is this wired right? shooto Instruments and Amps 1 17th July 2006 02:47 AM
Deck Outputs Wired Together?? jdgonko Car Audio 2 22nd December 2005 04:51 AM
How to wired two 8" drivers MisterB Multi-Way 5 11th January 2002 02:02 AM
Page generated in 0.06023 seconds (80.18% PHP - 19.82% MySQL) with 11 queries
