Old 3rd August 2003, 09:43 AM   #1
Default Side firing woofers in 3-way
Hi
There's been some discussion from time to time on side firing woofers but not enough for me to make an opinion, so...
I had an idea to use the following drivers in a 3 way config:
1 x Peerless 850146 10" CSX side fired on a 400mm baffle
2 x Peerless 850488 5" HDS mids on a 220mm front baffle
1 x Peerless or Vifa tweeter (not sure yet)
XO for the woof/mid at around 125hz, mid/tweet around 3500.
What are the design problems I'm likely to face here?
Feedback much appreciated.
Mos
Old 3rd August 2003, 10:53 AM   #2
7V is offline 7V  United Kingdom
7V's Avatar
The wavelength of the sound at 125Hz is nearly 9 feet (2.6m) so you shouldn't have any problems with a side firing woofer but, if you're going this way, I would suggest a 3rd or 4th order low-pass filter on it.
Steve
Old 3rd August 2003, 11:01 AM   #3
Why isn't it a problem 7V? because those frequencies aren't directional?
It looks like a great way of making a more elegant cabinet. The Mission 782 have side firing woofers. Maybe it's just a coincidence, but most magazines rate them high, apart from the bass that seems a bit odd...
It didn't really sound odd to me when I listend to them in a store though.
Old 3rd August 2003, 11:48 AM   #4
7V
I was goning with a 2nd order. The values are large and I'm sure 2nd order will be fine.
Quite frankly, side firers seem to polarise opinion.
Mos
Old 3rd August 2003, 12:01 PM   #5
Send a message via ICQ to phreeky82
well if u did a search, you probably would have found my questions about it before i made mine
similarly, mine had a single 1" dome tweeter, 2x5" mids and 1x8". i went for the 8" because my enclosures were big enough, and a 10" (at least one i could afford) didn't have very good response in that size enclosure. by the way, i used all Response drivers.
i've tried a couple of things with mine to get good sound out of them. i originally put the mid/tweet xo @ 3.5k 2nd order. i then didn't bother crossing the 8"s over, but just ran both the mid/tweet combo, and 8" parallel in full range. i did this because i hadn't gotten around to purchasing components for the rest of the crossover, and i was thinking about bi-amping.
i am still yet to try it like this with the 8" facing inward, but facing outwards there was no imaging problem.
i then, using a active xo built into my pc, ran them bi-amped. i can change the xo freq variably with a slider. it will depend on your driver sensitivity and response, but i found around 130Hz to be good. this was because my 5"s (in a sealed enclosure) response started to get around -1dB at this point.
i would honestly like the 8" to be on the front, but a 10" like you're using would be a little big. i however want the small front profile of these cabinets of mine (around 16cm wide externally).
i should also mention that my 8"s are also sealed, but the response down low is fine for music, and for movies i have my sub (so ultimately i'm running a 4-way system for movies ).
Old 3rd August 2003, 12:16 PM   #6
7V's Avatar
Yes, keep the freqiencies low enough and you could even put the woofers in separate boxes, I do.
Originally posted by Mos Fetish
I was going with a 2nd order. The values are large and I'm sure 2nd order will be fine.
You're probably right. You would be 3dB down at 125Hz and 15dB down at 250Hz. For a side firing woofer in the same cabinet this will probably be fine. I would say not a separate box job though, with 2nd order at 125Hz.
Yes, this issue does polarise opinions. I suspect that this is as much psychological as actual, if the implementation is right.
Old 3rd August 2003, 01:35 PM   #7
SY's Avatar
IIRC, NHT uses a second order from the woofer in their well-regarded 3.3. You might even think about copying their idea of a tilted baffle and long, wall-loaded cabinet.
In most side-firing designs, the woofer loading is near the floor, a good thing for bass smoothness (see Roy Allison).
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 3rd August 2003, 01:57 PM   #8
The difference is in center-to-center spacing.
If the centers of the bass unit and midrange are ½ wavelength apart at the crossover frequency, there will be cancellation there. If they are ¼ wavelength apart there, there might be some cancellation, like 3 dB. If they are much less than ¼ apart, you don't have to worry.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 06:32 AM
side firing sub chainenoble Subwoofers 2 23rd October 2006 06:35 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
side firing sub chainenoble Subwoofers 2 29th August 2005 03:29 AM
side firing woofers ogp Multi-Way 2 9th January 2002 01:44 AM
Page generated in 0.10125 seconds (84.72% PHP - 15.28% MySQL) with 10 queries
