i'm in the process of renovating a pair of rega el8 speakers and i'm thinking of rewiring them internally with cat5 cable, anyone tried this?
cheers, jim |
#2 |
Nothing better then rewiring with non ofc 24 gauge that melts when you look at it. you would need 16 pieces to make 12 gauge. Id stick to solid core the same gauge as your speaker wire, just like everyone recommends. If you still want to use cat5, at least use the solid core stuff.
I cant wait for cat5 audio cables to be on mythbusters. The stuff does not belong anywhere in analog equipment. Some guy spend hours braiding together 32 pieces of the stuff back in 1995 and now some people think its great because its hard to do and looks nice. |
#3 | |
Why it does not belong in audio-equipment beats me... Belongs there more then some of the "high-end"-products which contain more marketing-BS then conductive material. Scanspeakman
Scanspeak rules! Last edited by scanspeakman; 22nd March 2011 at 03:45 PM. |
#4 | |
I use shielded CAT 5 for my phono leads- works perfectly, easy to fabricate (10 minutes), low noise pickup, cheap as can be. What's the problem? I don't see the advantage for speaker use over plain zip cord.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
Ahh - a perfect digital cable that will only transfer 0's and 1's......?
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#6 |
Sorry for the rant. Ive just seen unshielded cat5 used in signal wire in car installs at it was horrible due to no shielding. Even the car audio guys are catching on.
It might be fine if its for tweeters, or if you can bunch enough of them together to make 16 gauge or so for woofers, but why not just use standard solid core that stays put and not have to deal with soldering 8 or more leads at once? I still say zip cord for the win. I Just use the same cable as im using for the outside of the speaker unless the speaker has a really odd interior. Last edited by nightanole; 22nd March 2011 at 06:23 PM. |
#7 |
well its been wired up (3 strands, per connector) and....sounds, not sure yet. more listening required i think. its only about 50cm lengths so i doubt it really makes an audible difference? very easy to work with. i even made up a pair of din-phono cables.
#8 |
frugal-phile(tm)
I've been happily using single strands of solid core CAT5 for both internal & speaker cable. Mind you in FRs not multiways with XO.
And at least a couple cases documented on thi forum, where the suggestion of replacing 12-18g multistrand zip with single strands of CAT5 have overcome specific problems with the sound. Speaker wire is very context dependent. One cannot make blanket statements. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#10 |
frugal-phile(tm)
| why use CAT5 cable? | mondogenerator | Full Range | 55 | 31st January 2010 03:54 AM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| Which cable to use on Aleph internal wiring? | Sony | Pass Labs | 4 | 25th May 2005 02:05 AM |
| What cable for internal wiring? | roibm | Everything Else | 11 | 27th November 2004 11:18 AM |
| Page generated in 0.10374 seconds (76.40% PHP - 23.60% MySQL) with 10 queries |
