Old 19th March 2011, 11:28 PM   #1
Jameslc is offline Jameslc  Australia
Default 3 way speakers impendence
Hi all i am building some 3 way speakers and i am wondering what will the total impendence going into the amp be if i have 2 woofer in series 8ohms each and a midrange that 8 ohms and a tweeter that is 6 ohms or will it be a constant impendence set by the crossover ?
Old 19th March 2011, 11:35 PM   #2
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Impedance (correct spelling) is a function of frequency and the impedance changes as the frequency changes. You have to remember that a crossover is a frequency dividing network.
Two 8 ohm woofers in series would be 16 ohms.
So in the range of frequencies (bass) covered by the woofers, the impedance would be 16 ohms, then in the range of frequencies covered by the midrange the impedance would be 8 ohms and then in the range of frequencies (treble) covered by the tweeter the impedance would be 6 ohms.
The impedance curve (graph) of a completed loudspeaker system looks like a roller coaster, up and down and up etc.
Old 20th March 2011, 12:26 AM   #3
ok so it should be fine but with the tweeter is 6 ohms should that be ok with my Denon Pma-501 because it supports 4,8,16 ohms ?
Old 20th March 2011, 12:58 PM   #4
AllenB is offline AllenB  Australia
Yes, it should be OK.
Old 21st March 2011, 01:32 AM   #5
thanks for the reply
Old 21st March 2011, 01:44 AM   #6
I'd be running the woofers in parallel.
what drivers are you using?
Old 21st March 2011, 11:58 PM   #7
i am running Peerless 830669 12" Woofers in isobarik configuration because i wanted to get low freqs but limited on the box size
Old 22nd March 2011, 12:29 AM   #8
and the other drivers?
sealed or ported?
Old 22nd March 2011, 08:06 AM   #9
Peerless 830669 12" Isobarik Woofer ported
Peerless 831916 6.5" Midrange Sealed
Vifa D27TG-45-06 1" Tweeter
Built differences between Guitar Speakers and PA Speakers? agadis PA Systems 7 24th September 2007 08:22 AM
FS : Studio One Pi Speakers aka Fred's EZ speakers Cacophonix Swap Meet 6 10th September 2007 10:56 PM
Does a really big PS in an Aleph 30 help drive low impendence loads? audionut Pass Labs 5 15th February 2006 10:38 PM
How would you compare your DIY speakers to commercial speakers? AJ Bertelson Multi-Way 20 28th May 2004 03:20 PM
About the wire impendence audioart Solid State 2 10th February 2004 12:44 PM
Page generated in 0.08662 seconds (78.19% PHP - 21.81% MySQL) with 10 queries
