What does it mean if u can touch/poke the cone on dead mid/bass driver and it temporarily comes back to life albeit distorted?
I hope someone will tell me its probably a solder joint! |
#2 |
Could be a soldered joint on the connector.
Otehr than that could be a broken voice coil that makes contact if the cone is moved in which case the speaker needs a recone.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
U got it! Ifound spark in pigtail connection, now how do I resolder it? Just reheat with solder iron or new solder joint? I don't think i have any solder
#4 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Yes!....Get your Iron up to temp, just a brief touch with the Iron, if your Iron is clean, (Properly tinned) it should just re-solder the broken joint. If it "sticks" to either the braided wire or the terminal assy, then your going to need 'more' solder. Either way you found the bad connection.
__________________________________________________ _____Rick..... |
| I'm seeing dead people | freeman | Audio Sector | 0 | 24th January 2011 11:20 PM |
| Are you REALLY going to be dead ? | ashok | The Lounge | 121 | 9th December 2010 03:32 PM |
| Dead Dead Laser Pickups - why not replacing the Diode only? | Salar | Digital Source | 9 | 24th January 2010 01:44 PM |
| dead amp | ddoyle | Chip Amps | 20 | 30th July 2007 01:30 AM |
| Page generated in 0.08148 seconds (72.27% PHP - 27.73% MySQL) with 10 queries |
