Some have metal diaphragms most have nonmetallic possibly plastic and the early ones seem to have paper. These are the ones that interest me. Searching but not one forum post about sound quality. In English anyway. Can anyone help? I am tempted to buy a pair. I looking for a warm tone. Someone said there good for 600 to 12k someone said 1k to 12k. Lots showing up on the Russian Ukrainian ebay markets cheap.
#2 | |
sergey |
#3 |
Thanks for your reply .Yes they are factory rated for 16k I was mistaken. Did you test them for sound quality? Did you test them on horns?
#4 |
yes.
in standard aluminum horns that they should use. throat and everything else looks similar as a TAD. they have a peak around 1700hz, but otherwise is pretty flat. No that much 'air'. about sound quality -is hard to say now. Was 5 years ago. It was not bad at all, but was not something remarkable also. considering the price -they worse it. huge alnico. you can play with diaphragms. I use to have 50 of them brand new. that's the only driver which is interesting from all Kinap.
sergey |
#5 |
Thanks Grec13
| Compression drivers or cone drivers - what do you prefer? | Defo | Multi-Way | 25 | 28th February 2010 10:57 PM |
| Compression ratio and diaphragm size in compression drivers | inkasound | Multi-Way | 50 | 8th January 2009 03:38 PM |
| compression drivers | edwgreen | Multi-Way | 2 | 29th November 2006 04:38 AM |
| 21" Bass Drivers and Beyma Compression Drivers | Magnetar | Swap Meet | 0 | 19th November 2006 02:42 AM |
| Page generated in 0.07232 seconds (74.51% PHP - 25.49% MySQL) with 10 queries |
