Old 14th March 2011, 03:34 AM   #1
Default Open to Surgestions
Hi guy's Great Site,
Just looking for some Guidance / Ideas
I am thinking of either the Delta Pro 18 A or the Sigma Pro 18A2 and using the Cubo 18 Cabinet Design, But i really like the Look of the MTH-46LC
Now the 18's should give me some Really good Low end, But to Give My Bass Some Punch i thought i would use some Delta 10's in a Ported enclosure these could also fill in the midrange,
Now as to the actual configuration X-Over etc i am undecided what to do,
i was thinking 1x18,3x10 Series Parallel on a 2 way crossover about 2.5k-3.5k plus Tweeter,
Or would be better with 1x18,4x10 3 way crossover 250-3.5k
But i think this would starve the 10's of any real punch.
Anyone have any good idea's about plans for the 3x10 Delta 10A.
I am relatively new at all this, and decisions decisions decisions
The rig is for Home use Movies & Parties and will be powered by a Hardon Kardon Amp.
Acreage and a large house is great
Old 14th March 2011, 03:47 AM   #2
picowallspeaker's Avatar
Hi ! What are those numbers and multiplications ? Are driver's diameter ?
Old 14th March 2011, 03:51 AM   #3
Sorry
I am thinking of the following Setup
1 x Eminence Delta or Sigma Pro 18 Inch
3 x Eminence Delta 10A's
Just not 100% sure of the Best Configuration
Old 14th March 2011, 04:06 AM   #4
You should certainly go Active . 3 X 10 in parallel means 8/3=2.3 Ohm or you've got to add one more to make series-parallel and have Ztot=8 Ohm. But you'll have to double also the 18s to have the same SPL
But you are active !
So what's the problem ?
Old 14th March 2011, 04:09 AM   #5
Thats where i'm Stuck ?
One thought is go series Parallel, with the 18, giving me 8 Ohms and a 2 way passive,
or
go 3 Way, and use 4 10's,
But i don't want to loose the punch the 10's give to the bass
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Open Source, Open Architecture! zenmasterbrian Digital Source 185 23rd February 2007 10:35 PM
CD player Drawer open close open close open close qguy Digital Source 7 23rd November 2006 08:58 PM
Page generated in 0.08026 seconds (72.85% PHP - 27.15% MySQL) with 10 queries
