I am after a driver to use from hopefully 150 Hz to around 1000 Hz in a yet to be built plywood 100cm tractrix horn. I have learnt the basics on Hornresp and would like some drivers to model.
Let me know your thoughts and drivers I can simulate. |
#2 |
3GGG
Stereolab in Germany suggest Fostex 206E cf140Hz f. Fostex UltraFi - STEREO LAB I'd love to buy the Eleven Horns 140Hz Mahogany horn.....90Kgs, 90cm diameter...!!! Eleven Horns - lower midrange horn.... 140 Hertz Le Cleac'h... Andrew Sydney Home |
#3 |
The 130 to 150Hz horns around the 800/900mm diameter seems about right.
Could the 40" horn be 100Hz and not 200Hz?
regards Andrew T. |
#4 |
Sorry Andrew,
OT again: Deleted my previous post as it was to much OT. Note this is Le´Cleach. 40" is exactly what you get when using Jean-Michels spreadsheet for Fcut=200Hz. Ie the Elevens are compromises. Also the Stereolabs seems to be the rip-off of the century.
Brgds Lars |
#5 |
The following drivers are ones that I've either built with, or know first hand that work very well in horns.
Eminence Delta Pro-8A or 8B, the 8A is 8 ohms, the 8B is 16 ohms Ciare 6.38NdW Ciare 8.50NdW Faital M5N12-80, it is 12 ohms Faital W6N8-120 Beyma 6MI100 18 Sound 6ND410 18 Sound 8M400 18 Sound 10M600 B&C Speakers 8PE21 B&C Speakers 10MD26 Your overall goal will determine which driver will meet your needs the best.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way! |
#6 |
Hey 3GGG,
As I understand it you will use Hornresp for your design. Remember that "Constant Directivity" is useless(almost) except for basshorns, you should use "Directivity" at preferred angle instead. I guess this is more of a midbass design for 2*Pi. A full 130Hz Tractrix has a min. length of 66cm2 and a max At of 130cm3.
Brgds Lars |
#7 |
Thanks guys
JLH, thats a nice list whicch should give me a few hours plaaying around with. My overall goal is to build the most detailed neutral sounding set of horns. For under 150Hz i am yet to determine what to do. I will build the remainder of the system first and see how it goes in room. The hard part is knowing where to start as each component links onto the next, therefore I have decided to start with the midbass horn. |
#8 |
3GGG
For under 150Hz, why not try the GOTO bass horn, which Ming Su and I developed. It's good for 300Hz, and you can run the Altec 416 driver. I could cobble together a flat-pack kit... I've also developed a non CNC'd/sliced model...using traditional flat panels. Cheaper option in either MDF or 25mm ply. Andrew. Sydney. |
#9 |
Is the driver going to be compression loaded? Or is it simply a speaker firing into a horn. IOW, is the throat area "smaller" than the driver's area?
#10 |
416 specs here
http://www.greatplainsaudio.com/downloads/416_8C.pdf Throat is 585cm2, or 90 square inch |
| Looking for phase plug ideas for horn loaded 10" and 12" drivers | Eva | Multi-Way | 10 | 11th December 2011 05:17 PM |
| who makes 18" x 12" x horn 3-w box??? | mastadon | Full Range | 2 | 29th October 2009 08:31 PM |
| Hemp 8" Coax and Tractrix horn? | bambadoo | Full Range | 4 | 25th May 2007 06:13 AM |
| Is it worth buying cheapy 15" driver or expensive 12"? | VEC7OR | Subwoofers | 7 | 26th February 2005 10:09 PM |
| Best Value 8",10" or 12" Driver | cj.9 | Subwoofers | 15 | 8th December 2004 10:28 AM |
| Page generated in 0.11947 seconds (73.40% PHP - 26.60% MySQL) with 11 queries |
