Just curious... The title sort of says it all. I just built some mini-towers that are sort of roughly assembled, and should feature some significant losses around the baffle and rear panel that allows access to the crossover. Before I solidify everything by gluing it all up and reducing losses as close to nil as I can get them, I thought I might try to hear (but not test) exactly what losses sound like in a sort of before-and-after situation.
(I know Vance Dickason touches on this briefly, but he didn't pay a grad student to write an index for him, and I don't think even if I found it I'd get a simple enough answer to understand... Thanks!) |
#2 | |
#3 |
You are referring to leakage, not losses. In the extreme leakage case you have the dipole speaker which is basically the front baffle on its own. They are reasonably popular.
#4 |
Losses can occur if there is too much damping material inside the enclosure and/or if the port-vent is blocked or too small.
#5 |
An aperiotic design relys on loss to damp the impedence curve among other things.
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#6 |
What type of system are your mini-towers? If closed-box (sealed), then large losses could result in Qtc lower than expected. That is,
Qtc = Qts*sqrt(alpha + 1) holds true only if (Qmc/Qec) = (Qms/Qes) The above is rarely the case as every enclosure introduces some losses. Losses diminish Qmc. So unless Qms >> Qes, you can expect that the actual value of Qtc is less than the target value. Further then, f3 is higher than expected. Regards, Pete |
#7 | |
-Pete |
#8 | |
#9 |
Some programs such as Unibox alow specifying different amounts of "box leakage" so you can get an idea of how much effect leakage will have on a given box design.
#10 |
Whilst I think this cardboard cabinet has potential and is very interesting, I think your main concern might be the frequencies where the basket of the driver resonates with the baffle so that some sound gets lost. In other words, the speaker wont see a solid mounting at some frequencies and energy may be lost. This won't necessarily be in the bass and if it is, won't necessarily have anything to do with the enclosure volume.
Fortunately, this would probably show up in measurements. It should also be easy enough to alleviate by bracing the front baffle etc. |
| Compare IGBT-losses and MOSFET-losses | kall | Power Supplies | 12 | 13th September 2010 05:01 PM |
| help !! calculating switch losses | dead rat | Class D | 0 | 16th December 2008 03:33 PM |
| Reverb insertion losses | ThSpeakerDude88 | Tubes / Valves | 5 | 28th January 2008 02:50 PM |
| Mesure box losses | REALFLEO | Multi-Way | 2 | 7th February 2007 01:06 AM |
| Thiele-Small R_ms (mechanical losses) vs. "precise" sound? | capslock | Multi-Way | 7 | 16th September 2002 09:32 AM |
| Page generated in 0.11174 seconds (80.11% PHP - 19.89% MySQL) with 10 queries |
